Old 04-18-2012, 09:22 PM   #1
Travis90
Travis90 is an unknown quantity at this point
Rb20 coolant lines
hey guys I am doing an rb20 swap and nearing completion but I am not a 100% sure where to run the coolant lines that come of the block I've read a lot of post about cracked lines and what not but but I've had trouble pin point the exact location of the where lines need to be run I am new to the rb so any help would be super appreciated!
Travis90 is offline   Reply With Quote
Old 04-19-2012, 04:13 PM   #2
shocker854
shocker854 is an unknown quantity at this point
Send a message via AIM to shocker854
Check the fsm? If you post up a pic of the ones you are having issues with, maybe I can help you.
shocker854 is offline   Reply With Quote
Old 04-19-2012, 05:22 PM   #3
mentordrift
mentordrift is an unknown quantity at this point
Send a message via AIM to mentordrift
Front is feed and rear is return, iirc...turbo line is back of the block into a tee near the rear coolant fitting. Line at the firewall top is feed, bottom is return, return goes into the same line with the turbo coolant line.
The pain in the arse coolant heat sink looks like an octopus, it's attached to middle area.
mentordrift is offline   Reply With Quote
Old 04-19-2012, 11:03 PM   #4
Travis90
Thanks guys I will post some pics up tomorrow for more exact details, but that is super helpful.
Old 04-22-2012, 10:55 PM   #5
Travis90
Sorry I hadn't posted up yet mckenny is killing me on getting the mounts in so I haven't had any need to be near the motor.
