Old 02-02-2004, 12:37 PM   #1
ISTOTOSAO
ISTOTOSAO's Avatar
ISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enough
Question dday brake requirements?
I was just at the dday site going over the requirements to participate in dday 13. I am cleared on everything except maybe the brakes. They work just fine; I just don't have the stiffest peddle feel. What I was wondering is how stringent are they on peddle feel. I just got my car to where I feel confident throwing it around, and I want to throw it around! So if anyone could somehow explain how much pressure I need in the peddle that would be great.
P.S. I tried the FAQ fix and the brakes dragged afterwards.
ISTOTOSAO is offline   Reply With Quote
Old 02-02-2004, 06:06 PM   #2
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
you should be able to put pressure on it and feel a response....no long delays.Make it comfortable for you, but also it can't be too close to the ground.If it takes you too long to get a reaction from your brakes it is probably too low. Make sure your brake fluid is clean, and that you have AT LEAST 50% tread. Also...make sure your battery isn't going anywhere....no movment at all...this is what they are the most stringent on.
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline   Reply With Quote
Old 02-02-2004, 07:41 PM   #3
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Re-bleed your brakes. And buy more fluid. DOT 3-4.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 02-03-2004, 12:09 AM   #4
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
Yep, rebleed your brakes and install new brake pads (if required). Then take it down to GSpeed or CarTune and get pre-tech'd. It's better to find a problem now than later..
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 02-03-2004, 01:32 PM   #5
ISTOTOSAO
ISTOTOSAO's Avatar
I had no idea that I could get pre-teched. I have pads that are still really new; front and back. I have bled the breaks several times. I can lock up the breaks if I stomp on it. It is just squishy. I am hoping to get steel lines before the event. That should firm it up some. I think I will go get pre- teched to make sure all is okay. Does it cost anything?
Old 02-03-2004, 06:45 PM   #6
S13SilviaGirl
UGH Really?
nope, pre-tech is free at the designated locations. If you wait until DD it cost $$$
My Review Thread
