Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 06-16-2012, 01:32 PM   #1
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
24 Hours of LaMans - Nissan Deltawing
OK so I can't post this in the Nissan News section so here it is....
Currently the 24 Hours of LaMans is on Speed, and today is the first time Nissan is running the all new Deltawing... what is it?
Originally Posted by AutoBlog.com
The Nissan DeltaWing took it first laps at Circuit de la Sarthe yesterday during practice sessions for the 80th running of the 24 Hours of Le Mans that's fast approaching. The world's oldest endurance race takes place in less than two weeks. While the DeltaWing underwent its first public testing session back in March at Sebring, this is the first time its drivers – Michael Krumm, Satoshi Motoyama and Marino Franchitti – have driven it at Le Mans.
The team was able to complete 54 practice laps, almost all of which were on the same set of tires. A brief instance of weather allowed for a single lap to be run on rain tires. The DeltaWing's quickest practice lap of 3 minutes, 47.980 seconds came at the hands of Motoyama. Based on the results of last year's 24 Hours of Le Mans, that lap time would make the odd-looking DeltaWing competitive with the LMP2 class of cars, and notably quicker than either class of GT cars.
The DeltaWing will compete at Le Mans in the experimental "Garage 56" class meant to showcase innovative technology, and with half the weight, half the horsepower and half the aerodynamic drag of a typical Le Mans Prototype car, should consume tires and fuel at a much lower rate than the rest of the field. Backed by both Nissan and Michelin, the DeltaWing is powered by a 300-horsepower 1.6-liter Nissan DIG-T turbo engine and rides on special tires developed by Michelin that are only four inches wide in the front.
http://www.autoblog.com/photos/nissan-deltawing/
http://www.youtube.com/watch?feature...&v=dUBwNu_AY8I
ENGINE
Type: 4 cylinder 1.6-litre Nissan DIG-T (Direct Injection Gasoline-Turbo)
Maximum Power Output: 300bhp at 7400 rpm
Maximum Torque Output: 310Nm constant from 4000 to 6750rpm
Throttle Body: Diameter 50mm from Nissan 1.6-litre normally aspirated Juke engine
Throttle Type: Drive-by-wire
Cylinder Bore: Linerless with spray coating, as used in Nissan performance engines and future downsized road car engines
Cylinder Head: High flow tumble port similar to road car DIG-T engines, a Nissan Pure Drive technology
Cam Shaft: Features diamond-like coating and nano finish, both Nissan Pure Drive technology
Water Pump: Electrically powered on DeltaWing, Nissan road cars will adopt electric water pumps to improve fuel efficiency in future
Cylinder Block weight: 15kg
Engine weight: 91kg
Oil sump: Machined from Aluminium billet for light weight and to reduce engine height for installation
Fuel type: Le Mans Shell E10 petro 98RON
Exhaust system: Inconel 4 into 1 exhaust with external wastegate
TRANSMISSION
Gearbox: 5-speed sequential
Clutch: 2 plate carbon. 4.5”
Shift System: Electrically actuated direct barrel rotation paddle shift
Crown wheel and pinion: Planetary final driver potentially featuring efficient torque vectoring differential technology
Drive shafts: Equal length tripod-jointed half shafts
CHASSIS
Chassis type: FIA homologated carbon fibre monocoupe
Front suspension: Double-wishbone, unequal length, with coil over shock units to lower wishbones. 4130 heat-treated thin wall tubular steel welded construction
Rear suspension: Double-wishbone, unequal length, with pushrod/rocker actuation of coil over shock units. Motion ratio discriminiation between heave and roll via fulcrum arm on rear anti roll bar axis
Dampers: Coil over hydraulic dampers
Anti-roll bars: Torsion bar (rear). No front anti-roll bar
Steering: Bevel quadrant steering box without power assist. Rear axle torque vectoring functionality will not be used in race mode
Jacking: Air jack
Fuel tank FIA-specification gasoline fuel cell
Brakes: Vented PFC Carbon/Carbon discs with 4-pot aluminium monoblock calipers
Brake bias: 40% torque bias front
Brake Ventilated uprights/air cooled
Front brake size: 280mm diameter, 18mm thick
Rear brake size: 320mm diameter, 25mm thick
Wheels: Forged magnesium 1 piece
Front wheel size: 15" diameter, 4" wide
Rear wheel size: 15" diameter, 12.5" wide
Front tyres: 10/31/15 Michelin
Rear tyres: 310/620/15 Michelin
WEIGHTS & DIMENSIONS
Weight: 475kg without fuel or driver, 575kg with fuel and driver
Weight distribution (front/rear) 28/72
Overall Length: 4.65m
Front width: 0.76m
Rear width: 2.08m
Height: 1.03m
Wheelbase: 3.05m
Track width (front) 0.6m
Track width (rear) 1.74m
Minimum ground clearance (front/rear) 30mm/60mm
Fuel tank capacity: 40 litres
BODYWORK
Tub and body panels: Carbon composite
Aerodynamics: Twin vortex underbody downforce system – BLAT (Boundary Layer Adhesion Technology)
Centre of pressure: 25% front, 75% rear
Coefficient of drag: 0.35
PERFORMANCE
Top speed: 315kph
0-100km/h: 3.3 sec
Fuel consumption: Estimated 230-250gm/kwh
FEATURES
Engine and transmission are “non-stressed members” in the chassis structural design which allows the installation of a wide variety of lightweight powertrains.
The car features a 4 cylinder 1600cc liquid intercooled turbocharged engine that will produce approximately 300 horsepower at 8,000 rpm and weigh 70kg.
Transmission is a 5 speed plus reverse longitudinal design with electrical sequential paddle shift actuation. The differential features an efficient variable torque steer/differential speed-controlled planetary final drive reduction layout with the entire transmission weighing only 33kg.
Vehicle weight distribution is necessarily more rearward than traditionally seen with 72.5% of the mass between the wide track larger rear tires.
76% of the aerodynamic downforce acts on the rear of the car which has a lift to drag ratio of >5.0.
Rear wheel drive coupled with the rearward weight and aerodynamic distributions greatly enhances inline acceleration capability.
Unique amongst today’s racing cars, more than 50% of the vehicle’s braking force is generated behind the center of gravity giving a dynamically stable response.
Locking propensity of the un-laden front wheel at corner entry is greatly reduced due to virtually no lateral load transfer with the narrow front track/wide rear track layout, steered wheel “scrub drag” moment is virtually zero greatly increasing tire utilization and reducing mid turn understeer.
Advanced computer modeling of structures, impact energy management, aerodynamics, vehicle dynamics and tires has been used to develop the DeltaWing design.
Driver position, restraint layout and energy absorbing structures designed to meet the latest occupant survival criteria.
Hour 2 - 16:27:18 No 0 Deltawing has gearbox problem (Michael KRUMM)
Hour 4 - 18:40:21 No 0 Deltawing has had gearshift problem but ok now (Satoshi MOTOYAMA)
#0 DELTA WING DELTA WING NISSAN (Michael KRUMM)
....and it just got run off the track (by a LMP) and seems to be out of the race at this point... hopefully they get it back on track.
MadScientist is offline   Reply With Quote
Old 06-16-2012, 01:34 PM   #2
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
omg it's the new 240sx/silvia successor!!!
upsdude is offline   Reply With Quote
Old 06-16-2012, 01:45 PM   #3
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
No cup holder.
Old 06-16-2012, 02:03 PM   #4
drivens13
drivens13 is an unknown quantity at this point
Forgot about the premier of this car. I just tuned in only to shortly there after see the deltawing get run offcoarse by another driver.
Missed a car flip again. Drivers are lucky to be okay.
Everyone seems to be blaming the new younger drivers.The rule changes have allowed for more than normal.
drivens13 is offline   Reply With Quote
Old 06-16-2012, 10:12 PM   #5
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Sucks this car couldn't finish. I wanted to see how well it would do compared to the other cars.
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 06-16-2012, 10:20 PM   #6
MadScientist
After contact with the No.7 Toyota TS 030 Hybrid pitched the No.0 Nissan DeltaWing into the wall at the Karting corner, it was down to Japanese driver Satoshi Motoyama to try and get the car back to the pit lane. In these instances, the team is allowed to talk to the driver and coach him in what needs to be done to the car, but only the driver is allowed to touch his machine.
Motoyama tried everything he could to get the car going again, but with no luck. It was too badly damaged to be able to bring it back to the garage for repairs. He said afterwards: "When we went green I was trying to let the leaders by and not interfere with their race but the Toyota swung across and hit me very hard.
“Once I was on the grass there was nothing I could do. The Nissan DeltaWing was in the wall very hard but I was very determined to try to get the car back to the pits. The crew could give me instructions, but I am the only person who can touch the car. We tried for a long time to find a way to get the car back to the pits, but the damage was just too much.
“I had two great stints and was really enjoying my time in the car. We had a really long safety car period and I was really looking forward to finishing off my last stint. I have had such a great time driving this car and I’ve loved working with Marino, Michael and the entire team. We have really shown what the future of sportscar racing could look like – ultra efficient.
"I really hope I can get the opportunity to drive the car again, because we really do have unfinished business. I am certain the car would have run for a long time if not for the contact.”
Old 06-16-2012, 10:25 PM   #7
MadScientist
You know what pissed me off most about the Nissan Deltawing crash...
It was hit by a fucking Toyota...
and if the Toyota had hit another LMP it would have been a penalty... but because of the Deltawing design it was ruled as a blind spot.
Old 06-16-2012, 11:20 PM   #8
booey13
Trader Rating: (91)
Garbage ruling...Nakajima knew he was there. He was in the midst of passing him. It's not like the Deltawing crept up on him and he didn't realize it.
Old 06-16-2012, 11:32 PM   #9
gearhead55
gearhead55's Avatar
Originally Posted by Breitling View Post
looks like a penis
wow you are a bright one...
Yea, he knew he was there, but even before the crash they were was talk about how difficult this thing is to see. When you see it next to the LMP cars it really does look tiny. It was an error on Nakajima's part, but i don't think they could have ruled any other way. I mean the car isn't really even racing against anything else. Sucks major though. I would have loved to see this thing do well.
gearhead55 is offline   Reply With Quote
Old 06-16-2012, 10:49 PM   #10
Breitling
Breitling is an unknown quantity at this point
looks like a penis
Ls460, 240sx, Super Avenger, Chronofighter, Navitimer
Breitling is offline   Reply With Quote
Old 06-17-2012, 03:16 AM   #11
TheRealSy90
TheRealSy90's Avatar
I want this engine. What is it exactly?
Such a good signature.
Old 06-18-2012, 10:10 PM   #12
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
VK45 late model Q45 engine. Company in England did the LeMans prep builds of them. But yeah its the VK45.
If you are talking about the Nissan engine used in the other entries. The Delta wing cars engine was special, You could say it was a Juke engine on steroids and lots of them. LOL
If you want to hear some dope shit Mike over at Tower engineering just finished dynoing a SR20VET at 390 ft lbs of torque. With a Torque band from 3400 rpm to just over 6500 rpm and a 8500 rpm hp pk of 440. on a GT28! at 22lbs!!
New Video
Buy my mounts!
Old 06-17-2012, 07:37 AM   #13
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
While it does seem aggressive and unabashed, I can almost 'understand' the move...I'd bet money on the Toyota driver either carrying too much speed into traffic and ducking out of the way (assuming that the car wasn't there), or simply thought he cleared the D-Wing and was going to go wide in the corner.
Terrible in the way it occurred, but I do not believe for ANY instance that the Toyota driver did that intentionally to say the least. Watch enough wheel to wheel racing and you'll see it happens all the time. I also think in this situation more than anything else, the lack of front tire (slow speed) didn't help the cause at all in regard to holding itself to the outer line/not being careened off course as it was.
Old 06-17-2012, 08:02 AM   #14
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
310tq from 4,000-6750rpm. Thats the coolest shit
Old 06-17-2012, 08:46 AM   #15
MadScientist
I just woke up and realized I missed the end of the race.
If I am reading this correctly... LMP2 Class - Level 5 Motorsports just won with a 1,2 finish!! Hell yeah Nissan Power!!
Old 06-17-2012, 10:12 AM   #16
codyace
codyace's Avatar
Trader Rating: (58)
Bad source for sure, the team that won LMP2 was a Honda, Starworks was the team name.
Nissan Powered LMP2 cars though did round out the rest of the top 10 though, stinks they couldn't run down the Honda. I don't think Level 5 even has a top 25 car...
Odd shake ups in the GT Pro classing...I guess with enough restrictions they are finally able to keep the Corvettes behind the 'fashionable' entrants.
Old 06-17-2012, 01:02 PM   #17
word sux
word sux's Avatar
word sux is an unknown quantity at this point
nakajima picking up right were he left off in formula 1..
this guys seems to do nothing but crash...
word sux is offline   Reply With Quote
Old 06-17-2012, 04:34 PM   #18
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
I think the incident with the Delta wing had more to do with the LMP1 car just being aggresive on the restart & prolly didnt even see/know the delta wing was there????? Perhaps!!!
But overall I think the car did/was going well until that.
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 08-30-2012, 10:20 AM   #19
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
I fucking love bots. I wish I could talk like that. People would hate me and it would be perfect.
whiterps13 is offline   Reply With Quote
Old 08-30-2012, 10:43 AM   #20
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
r2d2 postwhore
spooled240 is offline   Reply With Quote
Old 08-30-2012, 11:44 AM   #21
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
Damn that looked intentional. Wtf that toyota should have been disqualified.
But I dont know the rules for LaMans races lol
Nissan DeltaWing Crash 24 Hours Le Mans 2012 - YouTube
Instagram @hiighboost @iasperformance
Hiighboost2 is offline   Reply With Quote
Old 10-17-2012, 01:34 AM   #22
Kevin920415
Kevin920415's Avatar
Kevin920415 is an unknown quantity at this point
lol still no cup holder..
You drive DA 2 fo tay?
Kevin920415 is offline   Reply With Quote
Old 10-18-2012, 10:12 AM   #23
MadScientist
At it again... this time in Atlanta.
Hopefully they get the car fixed in time!!!
Shit is quick!!!
Nissan DeltaWing crashes in Atlanta - BBC Top Gear
Old 11-03-2012, 01:50 PM   #24
ksingh2463
ksingh2463 is an unknown quantity at this point
The delta wing is an amazing concept. Its going to bring a lot of changes to the world of motorsports.
ksingh2463 is offline   Reply With Quote
Old 11-03-2012, 05:46 PM   #25
spiderlone
spiderlone's Avatar
Trader Rating: (32)
spiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nicespiderlone is just really nice
No it's not that design will never come into play with other race teams nor will anyone put they're thoughts into that design.
what is that hot wheels toy doing on the track with real race cars anyways
*-- SPIDER --*
spiderlone is offline   Reply With Quote
Old 11-03-2012, 06:57 PM   #26
riptor
riptor is an unknown quantity at this point
thats what they said about the 787B and look it not only finished first in class, it took the whole race. big things cam come in small packages yo!
riptor is offline   Reply With Quote
Old 11-04-2012, 01:04 AM   #27
spiderlone
spiderlone's Avatar
Trader Rating: (32)
way different story there, it was a engine difference not a complete chassis difference.
*-- SPIDER --*
