Silly Header Question
Hey all
This might be silly but its new to me.... Heres my current exhaust setup: Stock manifold Stock Cat no resonator half inch oversize plumbing stock muffler what I wanna know is when i install my header, would it be totally useless if I just upgraded the cat and kept everything else the same?
Who the hell needs a sig anyhow |
#2 | |
![]() Join Date: Nov 2003
Twitch-I think it will improve performance,but minimally....I know people who have done headers on a otherwise stock V8,with stock exhaust,and it made a nice difference,but I don't know about the 240 |
WOW addicted
![]() Join Date: Dec 2001
I've seen header dyno's with 10-12hp gains. good stuff depending on which ones. It will only help.
I think hotshot may delete the cat.. so check on that.
#5 | |
the cat converter that goes before the cat converter. were the o2 sensors connect to. its after the headers but before the cat. i mean isnt that wat it is. the thing were the o2 sensors conenct to. also if i dont do that it wont be smog leagal
my car will have an 02 sensor AND a cat....I Have to replace the o2 sensor onto the new header anyhow. Im getting a pacesetter unit BUT is using my stock muffler going to make the header useless?? I dont want to replace the muffler cause mines in good shape
#9 | |
#10 | |
![]() Join Date: Dec 2002
OBD-II s14 Hotshot header unit - replaces ALL part from header down to "Fake" CAT. Installed Random Tech High Flow CAT where the "fake" cat normally goes. And Finally the Apexi N! dual which mounts directly behine the high flow cat. Good thing about the Random Tech cat is the flanges. It doesn't require gaskets because it's self sealing. Oh I also rewired the 2nd O2 sensor which was originally located right after the stock cat. I moved it to the Exhaust just after the new cat. Also the 1st O2 sensor is mounted to the Hotshot header in almost the exact location as the stock header. All in all my exhaust consists of 4 pieces: Header-CAT-1st muffler section-2nd muffler section. With yours you should replace everything EXCEPT the muffler sections like you stated. Also rewire the 2nd O2 sensor like I did that way you won't get an engine light. If your is OBD-I(1 O2 sensor) then it should be the 1st one that mounts to the header, and disregard the rewire info. Hope this helps with your set up making sense. Also just a side note, the header WILL make signifcant power gains on the top end. Very noticable gains with your butt dyno. The stock header unit on all 240s was very restrictive. I mean just put the two side by side when you do the install and look at the pipe bends, it speaks for itself. Good Luck
Don't mess with my monkey...he's loaded. |
#13 | |
Uh, yeah.
#14 |
Just for reference.. an aftermarket header with an aftermarket exhaust on a KA is L-O-U-D..
I had silencers in my N1 Dual for a while (very restrictive) and there was still a noticable power gain, so I'm pretty sure you'd be happy with the results. The noise shouldn't be too bad with a stock exhaust as well. |
#15 | |
![]() Quote:
#16 |
morgan thats great.......yeah i dont want it to be loud- I cant wait...maybe ill record it before and after and post the sounds or something...
Quote: Originally Posted by twitchy OOOOOOOOOOOOOOOOooooooooooooooooh!!! Mu ha ha ha ha ha hahahah ??? Uh, yeah. um, thats what I say when im excited...think of the waiter dude on the simpsons....YEEEEEEEEEEEESSSSSSSSSSSSS!! I HAD A STROOOOOOOOOOOOOOKE..... nevermind... I was glad to hear what you had posted was all- its all pointing me in a good direction.
#17 |
Yeah I figured you were just excited. Glad to hear you getting the hang of it. Have fun modding your car!
Later
#18 |
i just installed a new hotshot header and full exhaust (HKS)...its not loud at all untill you really step on it but the sound is amazing...not annoying at all...removing the resonator is generally what makes exhaust loud and shitty souding...go for the headers...i love it and im sure you will too...BTW hotshot does not replace the cat...i have a 93 s 13..
#19 | |
#20 |
hotshot...are these similar to pacesetter you think? Id buy the pacesetter cat back system I saw on ebay to go with it if I Hadnt seen such poor quality from the kit on my dads car........Oh, my high (er) flow cat is from a 1999 Grand Prix GTP- the cat is big, flat and can be welded to my car. I can get it from the junkyard for $15
#21 | |
![]() Join Date: Mar 2002
And as others have said...with the addition of the header along with my Apexi N1 cat-back...it's LOUD....but me likes!!! -Bill
Once you go black you...well...you know.....lol!!!! |
#22 |
hey uh...you dont have to like...drop the motor or lift it do ya?? If I had the right tools and know how could i do it myself? Ill likely take it in though...how long do you figure it would take to install
#23 |
exhaust upgrades closer to the engine always make more of a difference than farther from it. so yes, a header is still good w/ stock muffler. it will be a bit louder but wont matter unless your muffler is just crap. id put back on the resonator (or any resonator the same size piping as what you have) as well as a hi-flow cat from catco. their only 50 bucks or less and flow a shitload better.
