Old 07-06-2012, 10:01 AM   #1
Titan
Titan is an unknown quantity at this point
KA24ET – Hard to start when cold – Fuelling Issue
Hey guys, it’s been a while since I posted here, but this has always been the best place for technical advice.
A few years ago I turbocharged my S13 KA24E with a T3. Basic details: FMIC, SAFC, 370cc CA18DET injectors, Walbro 255. The car ran great after the build for many years.
Since then the car has been sitting for the past year as I bought a daily driver (Mazda 3... very exciting I know). I have been busy reviving the car over the past 2 months and at the very end I've run into an issue. The car was running fine before it was stored.
The engine is very difficult to start when cold and I am certain it is a fueling issue.
It will turn over, but won't catch until I return the key to accessory on. After it fires it will almost immediately stall. The process will need to be repeated several times while blipping the throttle in order for the engine to remain running. Once it warms up there is hesitation and backfiring under throttle, but at least it remains running. Removing the plugs yields a flooding scenario.
I have performed an inspection or replaced the following parts / systems:
- Fuel pressure is consistent while priming, cranking, and running (40 psi)
- Injectors have been cleaned and flow tested on a bench last week
- New fuel filter
- Fresh fuel in the tank
- Checked MAF (Hotwire is clean)
- Checked IACV (Ports are clean)
- SAFC settings same as when car last ran well
- No ECU error codes
- Resistance of ignition coil is in spec (primary and secondary)
- New rotor
- New distributor cap
- New plugs and plug wires
- Spark is present on all cylinders while cranking (checked each cylinder with a spare plug grounded to the engine block)
- SAFC reading proper TPS signal
- Coolant temp sensor resistance in spec
- Air regulator valve is getting 12v signal when key is in accessory on
- New battery
- Rebuilt alternator
I have tried playing with the SAFC and base timing, but neither has given me proper results.
I have literally tried everything I can think of in addition to following FSM troubleshooting procedures. No avail. I would be very grateful if anyone has any ideas / solutions, as I`ve exhausted all my troubleshooting knowledge.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 07-06-2012, 10:29 AM   #2
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
dirty maf? dirty iacv? bad cold start sensor, not sure what it is called on your car.
seems to be the answer.
greenwood is offline   Reply With Quote
Old 07-06-2012, 11:09 AM   #3
Titan
I checked the MAF and IACV, all clean. I also checked the air temperature sensor and coolant temperature sensor. The resistance for both is in spec.
Originally Posted by souljaseth33
Try un-plugging the MAF and see if it runs/starts any better
Did that. It went into safe mode (not allowing me to exceed 2500 rpm). No difference in how well the engine ran.
Old 07-06-2012, 10:51 AM   #4
souljaseth33
souljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to all
Send a message via AIM to souljaseth33
souljaseth33 is offline   Reply With Quote
Old 07-06-2012, 11:02 AM   #5
zeebrah
zeebrah is an unknown quantity at this point
^ +1 also check o2 sensor. I had similar problem on my sohc (although not nearly as bad as yours) but idk how o2 is with your turbo setup.
Braaap
zeebrah is offline   Reply With Quote
Old 07-06-2012, 11:12 AM   #6
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
02 sensor shouldn't matter if he's using the SAFC. I don't even run one on my KA-t.
what it is sounding like is an old problem I had with mine, always check the MAF, that's first and fore most. then what you want to do even though you said you've looked, is check your SAFC and make sure it isn't set to anything stupid like v6 or v8. also make sure you're using the right sensor and not on something like the karman sensor. (if that's what it's called)
last thing you can try, is replacing your ignition coil with something like an MSD blaster 2. you say you checked spark and all, but I had an issue where spark was golden, but under load my coil was acting up horribly.
don't give up hope yet
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 07-06-2012, 11:25 AM   #7
Titan
Thanks for the input.
I checked the SAFC and all the settings are correct.
I will check voltage from the MAF again tonight.
I checked the ignition coil resistance (primary and secondary) versus a brand new one at the store and they were nearly identical. What are the chances of it being bad under load?
Old 07-06-2012, 11:47 AM   #8
greenwood
greenwood's Avatar
Even if the maf looks clean it can still be fucked up
Old 07-06-2012, 11:50 AM   #9
Titan
Noted, thanks. I'll pickup some electrical contact cleaner ontop of checking the voltage.
Keep the comments coming.
Old 07-06-2012, 11:55 AM   #10
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
like the guy above just said, the maf can still be messed up. it all depends on how much you're willing to spend, your exact issue sounds like everytime my maf pigtail came unplugged and fell off. so it's up to you on if you want to go to autozone and buy the MSD blaster coil 2, which is like $40. or find a local friend that can lend a MAF to you, the worst case senario is the the pin on your ECU plug is sliding out. make sure to check that, I had a few pins sliding out of my ECU plug and it affected my SAFC.
ALSO!@!!!@# if you can try and take a video, without doing too much to the car, you don't want to destroy it.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 07-06-2012, 11:56 AM   #11
Exas Spec D
Exas Spec D's Avatar
Exas Spec D is on a distinguished road
Set the timing back to stock and retard it a few degrees 'till it catches.
http://zilvia.net/f/image.php?type=sigpic&userid=71648&dateline=123643  0746
Exas Spec D is offline   Reply With Quote
Old 07-06-2012, 12:52 PM   #12
Butcher240sx
Butcher240sx's Avatar
Butcher240sx is an unknown quantity at this point
Maybe bad fuel in the tank. Or clogged injector. Drain the fuel filter and tank. Put new gas in the tank. fill the filter back up with seafoam or other injector cleaner. Replace filter and crank on it.
Don't Mess With Texas
Butcher240sx is offline   Reply With Quote
Old 07-06-2012, 01:25 PM   #13
Titan
I put 30L (8 gallons) of fresh fuel in the tank. The injectors were cleaned and flow tested on a special rig in a fuel injection shop less than a week ago. Brand new fuel filter installed. No luck.
Old 07-07-2012, 01:20 PM   #14
Titan
Cleaned the MAF this morning. No difference on a cold start. I also unplugged the MAF, no difference.
Anyone got any other ideas?
Old 07-07-2012, 02:25 PM   #15
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
if you unplugged the maf and no difference then you just answered the question... stop cleaning the maf and replace it.
85% that's your problem
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 07-07-2012, 02:29 PM   #16
Titan
The thing is that once the motor is warm it runs fairly well. It will start up and idle. Whereas when it's cold it takes 20 attempts at cranking then it needs to be kept alive with throttle input.
Old 07-07-2012, 02:33 PM   #17
weirdchris555
weirdchris555's Avatar
weirdchris555 is an unknown quantity at this point
Check star signal fuse? Or something similarly named. Drivers side foot area. Same problem I had, corroded fuse, then wrong fuse size
Sent from my SCH-I405 using Tapatalk 2
weirdchris555 is offline   Reply With Quote
