check clearances during oil pump change
Engine is sr20det rwd
hey got oil light on recently so replacing oil pump and cleaning passages, does anyone know which cylinder tends to dry first? i want to check my bearings and clearances and make sure theres little to no wear... also does any one have stock main and rod bolt torque settings? just trying to get it all in one posting to make it easy! thanks guys! Last edited by jedi03; 07-17-2012 at 07:51 AM.. |
#5 | |
if youre going to use graded bearings the clearances should be between 1 and 2 thou... 2thou MAX! (mains), rods can go up to 3thou and if youre getting bearings just get standard bearings, acls or something. torque settings are 60lbs main and 33lbs rods... tighten in 2 stages |
it all depends if one blocked up or not. i would be checking and replacing all if possible.
Cylinder 1 on mine died, 2,3 & 4 were all ok. alot of info on clearances are in the S15 FSM
nationaldriftographic.blogspot.com/ |
