Old 07-17-2012, 06:15 PM   #1
RP El Fresco
RP El Fresco's Avatar
RP El Fresco is an unknown quantity at this point
s13 Sr20det red top won't start fuel / vacuum r good
Hi guys
I was driving from Glendale to Ktown but when I was around Chinatown it die on me while on the freeway I down shift n it got me to Ktown n before I got home it stop n I couldn't start it I turn it on n reg it a little n it got me home. Yes I google already I check all my fuel lines the fuel pump is working. I checked my vacuum lines n they are on the dot. I google n I was reading it could be the egi/egi pump relay n that I need to check the ground cables. I work 8am-1am the next two days n only have Friday n Saturday mornin to work on the car because I work in the night n Sunday I work all day again. So the plan is to check all engine ground wires but I need help with that when can I find them the only one I found was the one by the throttle body n I heard there's another's one by the fire way. Any advice will help?
Thank you
RP El Fresco is offline   Reply With Quote
Old 07-20-2012, 12:36 PM   #2
RP El Fresco
i check the car out today everything is okay im drawing blanks the wires where good from the battery to the chassis to the chassis to the throttle body the ground for the coils n from the head to the fire way idk what could of goof wrong
Old 07-20-2012, 12:38 PM   #3
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
Check spark and timing
roboticnissan is offline   Reply With Quote
Old 07-20-2012, 04:37 PM   #4
RP El Fresco
Yeah just read about that thank you I'll try it when I get home
Old 07-20-2012, 04:43 PM   #5
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Wow, 23 and you didnt think about spark?
And how do you know its getting gas? Did you actually test the pressure? Just cause the pump primes doesnt mean its good
Old 07-21-2012, 01:27 PM   #6
RP El Fresco
Car has spark n getting fuel. What's next?
Old 07-22-2012, 08:42 AM   #7
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
It the car getting spark and fuel then have you check for compression. Usually you suppose to do compression tests right after the car warmth up othewire you will get improper pressure tests. Have you check to see if the fuel injectors spraying fuel.. Very important
kennedy8383 is offline   Reply With Quote
Old 07-21-2012, 01:29 PM   #8
future
future's Avatar
Trader Rating: (42)
Spark all the way to the plugs?
And did you check fuel pressure like i told you last post?
Old 07-21-2012, 01:41 PM   #9
RP El Fresco
yes i use the spark plug tester and i did check the fuel pressure. by seeing my spark plugs i notice that im runing rich
Old 07-21-2012, 02:40 PM   #10
future
future's Avatar
Trader Rating: (42)
Check compression and change your plugs and get a FPR if the fuel pressure is too high
Old 07-22-2012, 06:57 PM   #11
jedi03
bad ignitor?
