![]() Join Date: Dec 2011
![]() Feedback Score: 12 reviews
![]() Alright guys, I've searched and searched and then searched again and I'm stuck. I've recently finished my RB25 S13 swap and I'm having trouble getting the damn thing started. I know I am getting fuel(pump is priming and hoses going to engine are pulsing). I know my CAS is working(I've pulled it out with the key in "on" position and spun it and I can hear the injectors pulsing). So at this point I moved onto spark, started pulling coils and plugs and I stuck a spark plug into a coil and rested the threads on the top of the intake mani, a grounded bolt etc. and the plug isn't sparking. There was also fuel on the plug so then again I know it's getting fuel. I got a multimeter and checked what I could following the FSM and I ended up finding a bad coil pack.. but whatever I am using a coil pack that I'm pretty sure is good, and a brand new spark plug and I'm stuck. I am using a Chase Bays wiring harness so I'm sure the wiring is ok. I pulled the ignitor and tried checking it following the FSM with my multimeter and couldn't figure out what the hell it was saying to do. So if someone could help me find out a way to see if my ignitor is good that would be awesome. Maybe if someone could tell me how to check and see if voltage is getting to the coil pack harness too? I'm just stuck and I wanna get this thing started! Thanks in advance guys hopefully there's some guru out there that can help me!
Yea I have the engine harness grounded to the intake manifold, and then a ground from the intake mani to the shock tower. Should be good right?
