Old 09-17-2012, 10:11 PM   #1
xHellaFlushS13x
xHellaFlushS13x's Avatar
xHellaFlushS13x is an unknown quantity at this point
s13 Coupe Brake light problems
My buddies coupes brake lights, reverse lights and dash lights don't work. The markers, head and turn signals work though. Everytime we hit the brakes it blows the fuse. It is an RB20 swap, not sure if that has anything to do with it. No crimps or funky wiring to the lights but not sure about under the dash. Wires we've been tracing are Red with Yellow stripe and Red with Green stripe. Any help or pointers would be greatly appreciated. Thanks!
xHellaFlushS13x is offline   Reply With Quote
Old 09-20-2012, 08:45 PM   #2
graysil80
graysil80's Avatar
graysil80 is making a name for him/her selfgraysil80 is making a name for him/her self
try to put a biger fuse in it and see what happen if that dose work look a all the wire in the back and front and under the dash to see if u dont have a short in one of them
graysil80 is offline   Reply With Quote
Old 09-20-2012, 10:27 PM   #3
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
lol ... do not listen to that guy ^^
Putting a bigger fuse will just cause more problems. What was the last thing that you did before the lights started malfunctioning?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 09-21-2012, 12:18 AM   #4
Hardie
Hardie's Avatar
Hardie is an unknown quantity at this point
Good point do not put a bigger fuse in.
Check your voltages/amps coming through to the brake switch behind the pedal, good chance it may have moisture on it or just could be shorting out.
Hardie is offline   Reply With Quote
Old 10-02-2012, 11:37 AM   #5
240zach
240zach's Avatar
240zach is an unknown quantity at this point
no i know the exact problem for this it happened in my coupe. if you remove the brake light fuse your dash lights(including your HVAC) won't light up, brake lights won't light up, and your bumper lights won't light up. it means you have an exposed wire grounding out at either your:
1. wiring to bumper lights ( thats where mine was)
2. trunk harness to taillights
or 3. your gauge cluster harness.
check all of those wires and look at them closely. i can almost bet you that the cause is coming from the bumper light wiring being exposed.
Originally Posted by tapdeznutz View Post
lol you pulled out the fishing lesson, nice.
240zach is offline   Reply With Quote
Old 10-02-2012, 11:58 AM   #6
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
ditto! lol check the areas that move too like the trunk harness some times they break and can cause it to short out.
s14boy is offline   Reply With Quote
