Old 09-21-2012, 11:12 AM   #1
Mass_sr20
Mass_sr20's Avatar
Mass_sr20 is an unknown quantity at this point
Electrical help! no power windows
Hey everyone ive got a 95 240 and when i bought the car it was in peices, ive managed to get most of the electrical back together besides the power windows and horn, ive traced lines and found that the power mirrors work. i manually jumped the windows by taking door panels off and directly sending power to the window plug via battery, they work fine just not by the window switch. HELP! any input is greatly apprieciated
Mass_sr20 is offline   Reply With Quote
Old 09-21-2012, 11:21 AM   #2
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Have you tried looking in the FSM for wiring diagrams? That'll help you trace wires and look for grounds, etc...
VNG704 is offline   Reply With Quote
Old 09-21-2012, 11:35 AM   #3
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
make sure you have power going into the window switch. there is a thicker gauge white/black wire that should be 12v+ with the ign on.
if that is getting power then it's probably your switch or amplifier that is bad.
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 09-21-2012, 11:47 AM   #4
Mass_sr20
Mass_sr20's Avatar
Just checked the wiring, the switch is getting power , just not much so i traced back to the relay and that is getting around 11.5v so i checked the ground on the relay and is reading .07ohms
