![]() Join Date: Jan 2003
hks turbo timer install.
This is suppossed to be fairly easy but I have not seen any place with a write up on it. I cant figure out which harness this is suppossed to plug into. I am also thinking that I might have gotten the wrong harness. Any info on this wiring would help. it is on an s14
96' SE Turbo'd Super 60, S-AFC, SMIC, 370cc Injectors, Open Air BOV, Warblo 255 pump, Stage 3 Clutch Kyb agx, Sportline Springs Full body kit, Bomex rear, Drift sides, r34 front gunmetal rims, yok tires |
![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Harness? We don't need no stinking harness!
Turbo timer usually hooks up to power, ground, ignition, and ebrake ground. Man you ask as many questions as I did.
I apreciate all the help, I am just trying to make sure that I get everything set up correctly on this turbo install. For the last 2 years I have been trying to get one of my 240s turbod and I finally figured that I have been surfing around on here enough and should just man up and do it. You guys know so much about this that I would be a fool to try to do it alone. Thats what I like about having a 240 is all the help that everybody is compared to other car owners.
anyways I cant read jappanees so I am not sure what goes were. and how to plug it up. would you happen to know what wires goes were and what color they should be. Thanks bro
Tell us what kind of timer you are installing. SR20DET or KA24DET? It will help if you have the right timer harness for your ignition harness. Verify the P/N of the harness to the year of your car on a website that sells them. That part will be direct plug in. Open up your steering column and find the the only harness that it plugs into. You'll need to pull your center console to tap into your ebrake wire. 12V and ground should be easy to find. The trick on my HKS type I was finding the wires for RPM and speedo. The Japanese instructions showed where to tap these on my S14 SR20DET ECU based on the year of the engine. The important stuff is written in English. The # of pinouts were also different for the different ECUs so that helped me cross check everything. I counted pins three times and spliced once. Good luck finding the pinouts if you have KA motor, because that will not be in the instructions.
I plugged in the harness I got and grounded it but the car would not turn over or start until I replugged in the factory harness to itself. Any info on this would help.
how hard is this to hook up with out the harness and can anybody tell me what wires go were, it turns out that I have a twin turbo harness and a mitsubishi harness, how I ended up with these I have no clue, so if anybody can direct me to the right wires I would apreciate it.
it SHOULD be cake.
On the turbo timer power is usually red ignition is green (on my blitz) or yellow ground is always black accessory is usually blue GO BUY A MULTIMETER! Best thing you can get for electrical I promise. Open up the steering column. Set the multimeter to read voltage. Ground the black wire, and stick the red wire onto a wire on the car. If it reads 12+ volts thats your power. If it reads 0 and then if you turn the key once it reads 12+ thats accessory. If it reads 0 and you turn the key twice but dont start and it reads 12+ thats ignition. Ground is a wire to the car. So screw in the wire to the chassis. Cake. Run leads from the steering column or some of these wires you can also find on the stereo connector to make life easier. I recommend soldering and shrink tubing your connections(If you use cheap plastic connectors you'll only regret it later).
Thanks Maede, would you happen to know what color our ignition wire is, I can run the assesorie wire from the assessorie wire behind the stereo, and the ground is easy as well as the constant power, that will come off of the back of the stereo as well, is the ignition wire the one that actually starts the starter, if so I believe it is yellow with a black stripe, Thanks again for the help hopefully I will be up and running this afternoon.
I am also trying to figure out what color the rpm and the speedo wire color is. This would help as well.
![]() Join Date: Sep 2002
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
if its s13 i have the wires that are needed to tap into, but if s14 i couldnt help you
89 240 SR powered... ummm i promise its stock ![]() |
Thats to bad, hopefully I will be able to figure this out. If anybody has the colors for the ignition and rpm and speedo, I would apreciate it. I am also wondering if anybody knows were in the fsm I should look to find this info out. Thanks.
im having a simular problem. i bought the hks type 0 with the harness. installed everything as the instructions said and the car starts fine, but when i pull the e brake and turn the key off the timer shuts off as well... any help would be greatly appreciated.
#14 | |
![]() Join Date: Feb 2008
![]() ![]() Feedback Score: 16 reviews
Same here.
#15 |
![]() Join Date: Jul 2008
Do yourself a favor and just get a harness, don't chop up your OEM wires! RPM signal is right in the back of the cluster obviously. The FSM will tell you which one it is...trust me, I've seen it in there.
#16 | |
Ignition: Get a turbo timer harness and that will take care of the ignition wire. RPM: I just posted it. Speedometer: Pins 28 (Red/Yellow) & 35 (Red) come from the speed sensor into the "Electric Speedometer" located inside the cluster. (This is just extra info) Pin 29 (Y/G) sends the speed signal to the ECM. See above attachment for location of the wires. *If this info is incorrect, please correct me* Reference S14 FSM. Pages EL74- EL76. |
#17 |
![]() Join Date: Jan 2008
Trader Rating: (26)
![]() Feedback Score: 26 reviews
You're doing this without a plug and play harness?! It's like 15 bucks to make the install a breeze and no headaches. If you have the harness and its not working check your grounds! Make sure its bolted down to a good ground. Main ground for the timer and ground for the e-brake switch. I didn't read the whole thread sorry if this has been covered lol. Good luck.
ಠ_ಠ |
#19 | |
EL-74 - EL 76 of the S14 FSM. -Pin 22 is the ground wire that goes into the cluster. -Pin 12 is the RPM signal wire that comes from the ECM. -Color of wire is L/B. |
