Old 12-21-2012, 07:24 PM   #1
SilviaSteez92
SilviaSteez92's Avatar
SilviaSteez92 is an unknown quantity at this point
hole in power steering hardline
I have a larger alternator from a nissan quest in my s14 and it rubbed a hole in one of my ps hardlines. Think it would be possible to cut the section of hardline out and replace it with a hose that goes around the alternator?
SilviaSteez92 is offline   Reply With Quote
Old 12-21-2012, 07:57 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
You can try. I would use a hose that is a really tight fit around the hardline (and clamps too) since it won't be flared at all.
Old 12-21-2012, 08:09 PM   #3
240zach
240zach's Avatar
240zach is an unknown quantity at this point
or do custom power steering lines so it doesn't circle around the crossmember anymore and maybe put a ps cooler on there.
Originally Posted by tapdeznutz View Post
lol you pulled out the fishing lesson, nice.
240zach is offline   Reply With Quote
Old 12-21-2012, 08:18 PM   #4
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
if it's a hardline it's under a LOT of pressure and just using a hose with clamps it will most likely blow off.
SW Fab
shiftdrift is offline   Reply With Quote
Old 12-21-2012, 08:19 PM   #5
SilviaSteez92
I think running custom lines/ cooler is a little overkill for my dd, I just want to patch the leak. Yes, i plan on using a snug fitting hose as well as clamps on each end, guess ill give it a try in the AM and let you guys know how it goes. Oh i almost forgot to ask, any tips on how to drain the fluid out of the system before i cut the line?
Old 12-21-2012, 09:44 PM   #6
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
yes, cut and flare it. FLARE IT!!! If you don't have the right tools use a Philips screw driver to flare the tubing. The put the hose over it.
Hashiriya415 is offline   Reply With Quote
Old 12-21-2012, 10:10 PM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if its the high pressure line then no hose clamp in the world is gonna hold.
if its the low pressure line then go nuts.
Old 12-22-2012, 03:40 PM   #8
SilviaSteez92
Well i cut the damaged section of pipe out today with a dremel, and replaced it with a piece of power steering hose and clamps. refilled the reservoir with ATF and did a few runs up and down the driveway turning lock to lock. Hasn't leaked a drop so far, well see how it holds over time.
Old 12-22-2012, 03:44 PM   #9
future
future's Avatar
Trader Rating: (42)
Why do it ghetto and not just put a new hose?
Old 12-22-2012, 03:48 PM   #10
SilviaSteez92
cause this cost $5 and works like a charm so far. obviously if it doesnt hold thats what ill end up doing but for the price I think its worth a try.
Old 12-22-2012, 04:03 PM   #11
future
future's Avatar
Trader Rating: (42)
It will leak again and you will be fixing the same problem twice. Hi pressure lines, they don't have that name for nothing
Old 12-22-2012, 04:52 PM   #12
SilviaSteez92
To be honest i don't give a fuck if it does. I don't have the money for custom ran hardlines right now and its not leaking in the meantime so i'm happy.
Old 12-22-2012, 05:32 PM   #13
future
future's Avatar
Trader Rating: (42)
Haha all you had to say is you didn't have the money. I thought you were just being lazy
Old 12-22-2012, 05:54 PM   #14
SilviaSteez92
Nah if i was lazy i would've just kept refilling the shit till it broke. I fixed it the best i could with what i've got, and it works so everythings good for now.
Old 12-22-2012, 08:13 PM   #15
brndck
brndck's Avatar
if this is the line that runs across the front of the engine crossmember, then just does a 180 "U"-turn, its a low pressure line, kinda like a ghetto p/s cooler.
The high pressure line only runs directly from the p/s pump to the steering rack.
Still not sure how your ALT rubbed a hole in it. Pix maybe?
Old 12-26-2012, 11:37 AM   #16
TypeXFan
TypeXFan is an unknown quantity at this point
Hes right, the only hardline that runs in the direction of the alternator is that wanna be p/s cooler hardline and its a low pressure line. I deleted that out when I replaced my p/s lines with Chase Bays P/S kit.
TypeXFan is offline   Reply With Quote
Old 12-22-2012, 11:51 PM   #17
240zach
240zach's Avatar
Do you have aftermarket mounts? Cause some mounts have threw engine sit lower and could possibly rib untruth your line.
Old 12-26-2012, 12:40 PM   #18
pwhitersxs
pwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enough
Send a message via AIM to pwhitersxs
That's definitely the low pressure line. Same thing happened to me. A simple reinforced hose works fine. Just make sure that its not kinked and you'll be fine.
s13 sr20det
pwhitersxs is offline   Reply With Quote
Old 12-27-2012, 09:19 AM   #19
iRideFBMSR20det
iRideFBMSR20det is an unknown quantity at this point
Yes I have done this on my Volvo S60R.
But it's not just as simple as cut and clamp.
You'll need to flair both ends of the damaged line to make a proper seal.
Also make shore it's p/s high pressure hose.
I also used HD Volvo squeeze clamps to hold it.
No leaks after 3 plus years.
iRideFBMSR20det is offline   Reply With Quote
Old 04-30-2013, 04:55 PM   #20
SilviaSteez92
Got bored today and thought id update. It was most definitely a low pressure line, and the hose has not come loose or leaked a drop in months. Hard line does not = high pressure.
Old 04-30-2013, 07:52 PM   #21
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Of course not. The hardline that loops in front of the cross-member is a low pressure line made that way to act as a fluid cooler.
zombiewolf513 is offline   Reply With Quote
Old 04-30-2013, 07:54 PM   #22
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^^THIS, when I rubbed that line and got a hole on it, I just split a fuel line hose, put it over the hole and clamp it down. Hose acts as a spacer to keep it from rubbing again.
CLICK HERE!!!
