Old 03-29-2004, 11:17 PM   #1
sil40sx
sil40sx is an unknown quantity at this point
removing turbo from sr20det
does anyone have a link to some step by step instructions on how to remove the stock t25 from the sr20det, i know its not very hard, but i just want to make sure i do it right.
sil40sx is offline   Reply With Quote
Old 03-30-2004, 12:08 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
here you go:
1. find bolts
2. find appropriately sized tool to loosen bolts
3. loosen bolts
4. ???
5. PROFIT!!
it's not rocket science.
Old 03-30-2004, 12:16 AM   #3
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
Originally Posted by mrmephistopheles
here you go:
1. find bolts
3. loosen bolts
4. ???
5. PROFIT!!
You also might wanna check the variable transister actuating kineticisor(sp?) VTAK unit, most people don't have that shit, but while you're in there you might as well make sure it's not messing with ur turbo.
oh and step 4. maybe you should pull the bolts out after you loosen them, sometimes its hard to pull the turbo off over the heads of the bolts, even if they are loose but I dunno...
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 03-30-2004, 11:58 AM   #4
sil40sx
here you go:
1. find bolts
3. loosen bolts
4. ???
5. PROFIT!!
man! i didnt know i was posting on fresh alloy!
Old 03-30-2004, 05:56 AM   #5
PSI240SX
PSI240SX is an unknown quantity at this point
Sarchastic a$$holes lol. This is the short version, as I remember it. Remove heat shield 10mm bolts, remove downpipe 14mm bolts, while your down there remove the 8mm hoseclamp from the oil return line, remove oil and water lines from block with a 17mm and a 19mm socket, fluid will leak, start removing 14mm bolts that hold the manifold onto the head, and finally have lots of fun removing the hose clamp with long needlenose pliers that holds the metal water feed line into the rubber hose line, behind the head. Lift the entire assembly out. When out, bend tabs down that are on the 4 nuts holding the T25 to the manifold, remove nuts and voila! Make sure you save those tabs! They are needed when re-installing.
Thank You and Good Night. I'll be here all week.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 03-30-2004, 03:12 PM   #6
mrmephistopheles
Originally Posted by PSI240SX
a$$
you're such a nice guy, Jay!
think trial and error is the best learning method.. that's why I'm to lazy to write out instructions on stuff like this.. wait.. did I say lazy? I meant... busy...
-Kevin
Old 03-30-2004, 06:39 AM   #7
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
^what he said cept you might wanna take of the IC piping first... oh sometimes the intake inlet and outlet elbows can be removed for more room to work. the carbon canister needs to come off too.
I know its dirty as chit... had exhaust leaks. gotta clean..
edited order of pics
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 03-30-2004, 09:55 AM   #8
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
we should put this in FAQs!
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-30-2004, 12:26 PM   #9
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
Yeah, it's a real pain in the ass. My turbo mounting gasket blew out a while back (apparantly this a problem many SR owners go through). Make sure you secure those bolts from the turbo to the manifold very well. Even with the locking plates that are suppose to hold the nuts tight, they still rattle loose somehow. Might consider a tiny spot weld on the nuts that could be broken off if you have to remove the turbo again.
Mr. Badlose is offline   Reply With Quote
Old 03-30-2004, 12:28 PM   #10
Steeles
Steeles's Avatar
no the freshalloy answer would be to click here: www.google.com
Old 03-30-2004, 03:22 PM   #11
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
nicely done steeles
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 03-30-2004, 03:54 PM   #12
sil40sx
i think this is one of the funniest replies i have ever read.
