Old 04-03-2004, 12:14 AM   #1
CreAziaN
CreAziaN is an unknown quantity at this point
Send a message via AIM to CreAziaN
Question about my clutch pedal
At first, the whole thing would pop up fast, but now...there's a part that doesn't pop up that fast anymore. It's really easy to push the clutch in now too. Before, it would take a lot of force to fully depress the clutch, now it doesn't take much anymore. What does this sound like to you? This isn't the early stages of a slipping clutch is it? Fawk.......
CreAziaN is offline   Reply With Quote
Old 04-03-2004, 12:22 AM   #2
Andrew Bohan
i had a similar problem, then a couple days ago, one of the bolts that holds the clutch pedal bracket to the master cylinder through the firewall just snapped in half. i checked the other bolt and the nut was halfway off, so when i was pushing the clutch pedal in, instead of pushing that rod into the cylinder it was just pushing the cylinder away from firewall and then not springing the pedal back up. cost me $10 and half an hour to fix it.
short version: check the nuts on the bolts on the master cylinder that hold it to the firewall
Old 04-03-2004, 12:46 AM   #3
CreAziaN
should i check inside the car (under the steering wheel) or outsite (engine bay)?
Old 04-03-2004, 02:47 AM   #4
cowbomb
cowbomb's Avatar
cowbomb will become famous soon enoughcowbomb will become famous soon enoughcowbomb will become famous soon enoughcowbomb will become famous soon enough
return spring!
cowbomb is offline   Reply With Quote
Old 04-04-2004, 07:09 PM   #5
CreAziaN
Originally Posted by cowbomb
return spring!
is it bad if I don't fix it? If I don't fix it, will it just be like I'm riding my clutch when I'm not even pressing it?
Old 04-03-2004, 02:47 AM   #6
cowbomb
cowbomb's Avatar
look under ur dash or the bracket for your clutch might have snapped
Old 04-04-2004, 01:05 AM   #7
Andrew Bohan
look in both places for anyting fishy like loose nuts or things caught in the pedal arm's path like wires or something
man, my clutch pedal action is soooooo much smoother after installing the new bracket
Old 04-04-2004, 01:59 AM   #8
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Talking about clutches, My clutch guy ( one of the engineers for centerforce clutches), makes any clutch for me I desire. I get rb20, Ca18, sr20, and many, many more. Here is a basic one that is rated at 450hp. These meet or exceed comp. This guy that makes these, was one of the main guys for centerforce, he broke away from his colleges and started his own business. I can have normal performance clutches or any specs you chose he can make, for hundreds less. Single, twin plate, what ever. Ps: I am doing this for my friend, I make 0 cents off of any deal, I am sure my friend get nor money or some sort of clutch sponsorship, he just came by today, woke me up and told me to take pics of a clutch and send it to his email. I was instructed to let every one of the KA CA SR and RB family know. If you guys need a clutch let me know, and Ill tell you how much. They are good, all of our cars use them.
-Voya
TheSnail is offline   Reply With Quote
