89 Toyota Cressida 1jz
Location: NY car is currently in NC car can be picked up in NC or NYC Contact Info: 516-204-6188 text or call pics in link below will add more later Year: 1989 Make: Toyota Model: Cressida Color: Red Mileage: dunno cluster was changed only used to travel its very reliable n good on gas only made 6 trips between NY and NC only time car is driven otherwise stays parked Price: 7000.00 Nego Engine 1jzgte 14 and 12 inch Fans with flex-a-lite fan controller Working AC Turbo setup GT40 turbo 3in exhaust from turbo back Tial 50mm BOV 44m tial wastegate (15psi spring) -10an oil drain -4 oil feed HKS fcd car runs a solid 16.5 lbs (11.4 on wide band WOT) 2jz Map sensor AEM wideband and Greddy Boost and oil gauge FMIC Drivetrain Soarer R154 manual transmission one piece driveshaft Mk3 supra LSD (3:73) SS clutch line Suspension 300zx front brake upgrade Megan Coilovers new front hub bearings 350z rays track wheels Interior Grey Cloth Interior IS300-spoke steering wheel Gauges Installation kit to replace clock and air vent greddy turbo timer kenwood radio usb and aux with bluetooth and pandora whatever i missed u will on the car Bad: cold start issue (have to hold pedal until temp needle moves normal on these swaps) need dimmer switch..didnt get one with the car need diff rear bushings Turbo might need a rebuild or replaced was brought use no shaft play oil residue might be from stock twins blowing...(have another Turn to go with) Toyota Cressida GT40 1JZ
95 S14 sr20vet ![]() 90 1j Cressida |
