![]() Join Date: Feb 2002
Trader Rating: (29)
Enjuku Racing - Precision 5128 Turbo Chargers
![]() ![]() Precision PT4828 Turbocharger - Nissan SR20DET - Nissan SR20DET PTE's Direct Replacement Performance Upgrade Turbochargers feature the following: • Exclusive CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging • Liquid-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) • Higher efficiency and faster transient response for maximum power and performance • 51mm inducer compressor wheel • Compressor cover options: - "B" compressor cover 2.8" inlet/2.0" outlet - "E" compressor cover 3.0" inlet/2.0" outlet • 53.8mm, 76 trim turbine wheel • Turbine housing options: - T25 .64, .86 A/R wastegated - T3 .48 A/R with 5 bolt discharge (with wastegate hole) • Wastegate actuator included with "B" compressor cover and T25 housing These are Amazing Turbo chargers!! Rated to 450+ HP Easily!!!
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] ![]() |
Trader Rating: (29)
They are offered in a T3 turbine housing with .48 A/R.
Trader Rating: (29)
Your 2871R and 5128 utilize very similar sized turbine and compressor wheels, but the 5128 utilizes a smaller diameter center shaft portion on the CEA compressor wheel (due to the material and design it can use less material and still be as rigid) allowing the overall length/surface area of each individual blade to be larger. The larger surface area allows the turbo to generate a bit more power than a comparably sized 2871R.
![]() Join Date: Nov 2012
![]() price shipped to 11596...
also i bought an isis ka cold pipe and i want to buy the m-spec intercooler kit... can you leave out the cold pipe and include the greddy bov flage instead for the same price ??? |
Trader Rating: (29)
PM's sent!
Also for the intercooler piping question, call the shop (352)241-8399 and speak with one of the sales reps and they should be able to get that taken care of for you.
2 questions.
1) It appears that this compressor housing has holes drilled on the underside such that it can be re-clocked 180 degrees. Application: 300zx TT. Can you confirm if this can be used on a vg30dett? 2) How much for (2) shipped to 78613. Thanks, E |
Trader Rating: (29)
PM's sent!
