Old 04-02-2013, 11:38 PM   #1
WanganWizard
WanganWizard is an unknown quantity at this point
R32 GTR Partout! RUST FREE BC registered
RUST FREE BC registered clean titled R32 GTR shell - can negotiate what will be included as car is complete atm with no engine.trans PM with details about what you might want. (Roller shell with all body panels, glass, lights,fuel tank/lines/pump, full interior minus front seats, brake lines, suspension arms , would require wheels to roll $3000
Will provide pics to email, payment via PAYPAL accepted [email protected]
Vipec plug and play ECU - basemap for 750cc injectors $1300
Zeal coilovers (very low kms)- $1000
Sard/Denso 750cc top feed injectors (brand new, ran one tank of fuel through them) - $500
AEM truboost - $300
Innovate LC1 with sensor and gauge - $250 pending
GTR passenger seat, mint no rips or stains - $300
Bride Ergo driver seat some heavy wear on outer bolster with super low mount rail - 400
Snow performance meth kit, comes with tank,level sensor,pump,control module,wiring but no line - $200
Skylabs torque split controller - $175 pending
Kansai Service BRN32 lower race bar set - $350 pending
M's intake elbows and fiters- $250
Cusco front/rear strut bars - $300
XS power TT downpipe, test pipe, catback unknown JDM brand - $400
Brand new yellow jacket coils, used to test on a car once - $350
Unknown JDM lockout bar, chromoly, quality looks great - $80
Front/Rear calipers, drilled rotors, pads, rear hub assembly with ebrake and cables - $800
Complete uncut engine harness- $250
Valve covers, upper timing cover, coilpack cover, rear upper timing cover - $200
Complete intake assembly with itbs ,sensors - $300
Ceramic coated OEM manifolds and elbows - $200
Aftermarket knock detector - $80
AWD transmission, 100k, no whines or grinds, comes with shifter and oem knob - $500
Front axles - $160 pair pending
Rear diff/axles - $300
Tomei timing belt under 1000kms - $100
N1 water pump - $60 pending
OEM GTR Front Mount Intercooler - $150
Alternator - $80
Starter- $80
Turbo feed harline, blocks and banjo bolts everything needed EXCEPT crush washers - $100
Knock sensors/knock sensor harness - $180
lower engine harness (starter, alt, trans etc) - $80
coilpack harness - $50
crank pulley/bolt - $40 (not all busted to **** like most i see lol)
water pump pulley- $10
All parts are located in kelowna BC and i WILL ship. Prices are OBO within reason. PM is key!
WanganWizard is offline   Reply With Quote
