Old 04-25-2013, 01:04 PM   #1
Twin
Twin's Avatar
Twin is an unknown quantity at this point
Trying to charge me $160! blah!
So my local mechanics are trying to charge me 160 to remove and replace my 16 wheels studs. The dude says theyre gonna have to remove the spindles on the front wheels because they will get in the way and theyre going to have to replace the bearing as well. Replacing studs i can do myself but i dont have the time nor an impact gun. I dont know if doing it without an impact is safe. Also, im not too sure about the spindle and bearing deal. I think theyre just trying to jack up the price. What say you fellas?
Playas stay DONK!
Twin is offline   Reply With Quote
Old 04-25-2013, 01:25 PM   #2
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
Then pay the man!! If you dont have the time or tools then why bother. That price isnt that bad.
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 04-25-2013, 01:27 PM   #3
Twin
Twin's Avatar
So youre saying replacing the bearings and spindle is necessary?
Playas stay DONK!
Old 04-25-2013, 01:32 PM   #4
murffy
murffy's Avatar
Trader Rating: (44)
murffy is an unknown quantity at this point
Feedback Score: 44 reviews
I highly doubt they would replace your spindles..as for the bearings and studs for 160 is that parts included? Cause if it is that's effin cheap..I wouldn't do that job for 160 haha if the parts are not included then it's an alright price still..and yeah for the rear studs you have to remove the hub to be able to have room to
Put the stud in..and for the front if you still have your dust shield then yeah they have to remove the front hub to get to it too..a machine shop charges around 10 a hub to press in bearings so keep that in mind as well
murffy is offline   Reply With Quote
Old 04-25-2013, 01:39 PM   #5
Twin
Twin's Avatar
No no, they are only replacing the bearings. I have all 16 studs. All i need for them to do is the labor but i wasnt sure if 160 was a fair price.
Playas stay DONK!
Old 04-25-2013, 01:36 PM   #6
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
iim pretty sure the the new hub comes with studs.
Juantwo3 is offline   Reply With Quote
Old 04-25-2013, 01:43 PM   #7
jamg
jamg is an unknown quantity at this point
I'd pay $100 at most.
it's easy though, you should do it yourself.
jamg is offline   Reply With Quote
Old 04-25-2013, 02:10 PM   #8
Twin
Twin's Avatar
Is it ok if i torque the new studs without an impact?
Playas stay DONK!
Old 04-25-2013, 11:16 PM   #9
uraznfriend
uraznfriend's Avatar
uraznfriend is an unknown quantity at this point
torque wrench will be most adequate im sure in the fsm has the torqueing specs for the wheel studs
uraznfriend is offline   Reply With Quote
Old 04-25-2013, 02:21 PM   #10
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
You don't know if doing it without an impact gun is safe?????????
I should throw that gun at your face, seriously. That is the easiest way to fuck shit up. What you wanna use the impact gun for??? to bring the studs into the hub? Use a press or c-clamp to start it. Then tighten them slowly.
I've seen tons of people impact new studs on and then it spins, that's when your fucked. If you were not using impact, you would see it spin and stop, so you don't destroy your hub
Hashiriya415 is offline   Reply With Quote
Old 04-25-2013, 02:38 PM   #11
Twin
Twin's Avatar
What i mean by safe is if i can securely torque the new studs into the hub with manpower and be sure that they wont come loose you meanie.
Playas stay DONK!
Old 04-25-2013, 02:22 PM   #12
jamg
its possible but a pain in the ass.
you might as well spend the labor money to buy this-
Electric Impact Wrench - 1/2"
they have 20% off coupons all the time. Print one out, take it to the store, and buy one.
it will make the whole process much easier.
I've personally used an impact gun to get studs installed. first you LINE up the stud, put a bunch of washers, and the lug nut at the end of it.
Old 04-25-2013, 02:43 PM   #13
Twin
Twin's Avatar
yes im trying to find the most efficient way to do this. thanx man
Playas stay DONK!
Old 04-25-2013, 03:01 PM   #14
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
$160 including new wheel bearings is definitely a good price. Are your wheel bearings bad? You can pull the studs in by hand though. I usually use a spare lugnut, some washers, and anti-sieze to pull them in. I really need a wheel stud installer tool though, that's so much easier.
Old 04-25-2013, 03:21 PM   #15
Twin
Twin's Avatar
My bearings should be fine. Im not hearing any weird noises or anything. Ok ill try and do the rear 8 for sure on my own. thanx breh.
Playas stay DONK!
Old 04-25-2013, 04:56 PM   #16
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Lisle 22800 Wheel Stud Installer on eBay!
get this and go at it..
you can knock out the wheels studs with a BFH.
Then put the new ones in with the tool I posted above as well as a Impact, set on low.
should only take you a few minutes per hub.. Thats if you know how to remove a brake caliper lol.
MrSanchez925 is offline   Reply With Quote
Old 04-25-2013, 04:56 PM   #17
MrSanchez925
or you can use a lug nut and some spacers.... open end lug will be best to use.
Old 04-25-2013, 05:02 PM   #18
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
I always replace studs myself without an impact. I set them in with a clamp then draw them in with a ratchet/long steel pipe combination on an open lugnut/washer combination. Hard on your body but it's worked out for me every time.
slothonaleash is offline   Reply With Quote
Old 04-25-2013, 05:47 PM   #19
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
so much fail.
rwtf is offline   Reply With Quote
Old 04-25-2013, 09:03 PM   #20
Hashiriya415
Trader Rating: (22)
There is no problem with them coming loose if you pull them in by hand tools and always remember to loosen and tighten them up the next 50 miles. The new studs will stretch slightly at first.
Old 04-25-2013, 09:20 PM   #21
zurud
zurud is an unknown quantity at this point
If you don't have the time or the tools, pay up.
zurud is offline   Reply With Quote
Old 04-25-2013, 09:36 PM   #22
Hashiriya415
Trader Rating: (22)
All you need is a 5lb hammer and 17mm to get your rotors off. Hammer old one out, hammer new one in. Finish off by tightening down as needed. Just do it on the street. If cops ask, just say you were parking your car and the brakes fell off so you just want to put them back on
Old 04-25-2013, 09:42 PM   #23
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Dude, remove the rotors by the two bolts in the back, move the rotor and caliper together to the side (don't hit the brakes or ebrake with the caliper off of the rotor or you're fucked) use a big hammer to hit the old lugs out with a nut threaded on the end to avoid mushrooming, pull the new ones on using a nut. Just double check and make sure theyre all the way in. If they're extended lugs, you may have to take the hub off, but that is simply one 30MM nut holding it to the spindle for the front, not a big deal. Oh, never use an impact to put nuts or bolts in. Fuck that.
Nobody is going to give you a hard time about working on your car anywhere as long as you aren't spilling fluids all over the place.
zombiewolf513 is offline   Reply With Quote
Old 04-25-2013, 11:10 PM   #24
NoPistons!
NoPistons!'s Avatar
NoPistons! is an unknown quantity at this point
I read 5 posts in here before i decided to say you should pay the man. He's not robbing you blind. Just WATCH the mechanic/person as they are doing it if you are allowed to do so.
For the time, effort and task, $160 is a good price. I've rebuilt several sets of hubs, have had to replace wheel studs, have had to service brakes, rebuild engines. If you REALLY want to diy you need to get your hands on a haynes repair manual, download the fsm and use the search function on the various s-chassis resources you have at your fingertips but nobody is going to beat you up questioning the price of a job. Actually i encourage people get a second or third opinion before coughing up that cash.
Best of luck to you. For real though, if i was a noob (i used to be many years ago and still am in alot of ways) i'd be pumped to pay that little for a job like that. Locally, i'd expect to pay $400 for the same job if not more. Some "mechanics" are great con artists/thieves.
Just another broke ass drifter
NoPistons! is offline   Reply With Quote
Old 04-26-2013, 12:59 AM   #25
Twin
Twin's Avatar
Ok well sounds like the price is fair for the most part. Thats what i really wanted to know i guess. Im short on money so ill try to do the rear 8 on my own using the info ive read. Thanx to everyone. Cheers!
Playas stay DONK!
Old 04-26-2013, 01:23 AM   #26
chiboy002
the front are easy as shit too. why are you gonna do half, then take it to a shop?
seriously, get a wooden block and a metal mallet, ~3 pounds is enough. place block on lug nut and smack it with mallet, so you don't fuck up the threads and can keep them as spares/sell them
do one at a time and make sure it comes out, theres usually room to put them in/out where the caliper goes on the brake shield.
again, doing one at a time, put the new one in and hand tighten it as far as you can using an old open-end lugnut, reverse is better (flat surface) and some washers or an oversized nut. put your car in gear/ebrake (if for rear) or have a friend step on the brakes and then tighten it with a big ass breaker bar.
if you dont have a friend, use a wooden bat or something, i used the handle of a hammer, and use it as leverage to counter the spinning of the hub as you tighten the lugnut. stack books/jack stand and use it to lock the hammer in place so you can really tighten it down.
once done, move onto next. and so on. i did all of mine in like 2 hours, with no idea wtf i was doing. seriously, its not hard
even if it takes 4 hours to do, i doubt youre getting paid 40$ an hour to have it be worth your saved time to get a shop to do it
street dancer.
GLEAM
Old 04-26-2013, 03:24 AM   #27
LuckyRPS13
LuckyRPS13 is an unknown quantity at this point
Ok I stopped reading after a few posts. What I am gathering is this mechanic is going to remove all 4 wheels , brake components, press out bearings, press in new bearings, replace all the studs, and then put it all back together. $160 is hella cheap, no it is not hard work when you have all the tools on hand, but it is tedious. If you don't want to pay him his clearly undercut price do it yourself. I would charge you more if you brought it to me. No way I am hammering out all 16 studs that why I bought a press.
Do you need;
Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill
S13 Silvia J's, Q's, K's, A's Bumper grill inserts.
Male Plugs for S15 headlights
PM me if you need them.
LuckyRPS13 is offline   Reply With Quote
Old 04-26-2013, 03:28 AM   #28
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Could have done it yourself if all you need to do is replace the studs.
S13 Wheel Stud Replacement - Nissan 240SX Forums
HOW TO: Change a broken wheel stud : 240sx General Discussion
If swapping out hubs then goto Autozone and rent the axle sockets for $20 and the breaker bar for $25.
AutoZone also has a 50 Duralast piece tool kit on sale/clearance right now for $22 and a 22 piece Titan wrench set (SAE/Metri) for $20.
Pretty much all you need for most basics jobs on these cars.
Good price nonetheless considering the job.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-26-2013, 03:31 AM   #29
Twin
Twin's Avatar
Lmfao literally half the people are telling me to do it myself and the other half saying to take it to the shop. I clearly just need to figure this out on my own. Thanx anyways chaps.
Playas stay DONK!
Old 04-26-2013, 06:55 AM   #30
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
I think you just need guidance.... Maybe hold your hand also
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
