Old 05-29-2013, 07:26 PM   #1
AXV
AXV is an unknown quantity at this point
Those who have working S13 DCC please help me!!
Alright guys so I had a day off today I finally got around to installing my DCC. I bought everything together with uncut harness with all the sensors from the JDM S13. My problem is when I flip the keys for ignition on, the DCC unit wont light up/turn on.
I followed driftenthusiast's write up ( http://zilvia.net/f/tech-talk/154426...e-control.html ) but it just wont start. I referenced some other write ups as well, such as:
S13 Digital Climate Control Step By Step - 240sxONE Forums
S13 JDM Digital Climate Control Swap (It's easier than you think!) : 240sx General Discussion
JDM S13 digital climate control write-up thread
and all of them basically say the same thing. I thought well easy enough so i'd go ahead and do it.
I used a test light and I am getting voltage at the red and the blue connections. I think the problem might be my ground? I did not get a reading for ground from my test light.
I have attached pictures of what I did.....someone pls help!! This is my daily driver and I don't want to leave things as is. I read the write ups multiple times since last sunday and in all the write ups it said this was an easy install.
AXV is offline   Reply With Quote
Old 05-29-2013, 07:28 PM   #2
AXV
unless I am an idiot and forgot something else?
Old 05-29-2013, 09:55 PM   #3
AXV
c'mon i know there are many of you out there!!
Old 05-30-2013, 12:45 AM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Just find some metal bolts that are bolted to the chassis and use those for ground. You can use the bolts that bolt the shifter boot to the chassis.
^ Use one of the four bolts shown above.
Old 05-30-2013, 12:48 AM   #5
AXV
But it doesn't reach. Should I get another piece of wire to extend it? Did I do everything else right?
Old 05-30-2013, 12:54 AM   #6
KiLLeR2001
Trader Rating: (46)
Yes, extend the ground to reach.
Does the red w/blue wire receive 12V with key turned IGN. ON? Make sure it doesn't activate with key to ACC ON.
Also, you are forgetting to wire up the green w/ white stripe wire (JDM side of white 6pin harness). This also must be hooked up to IGN ON.
Old 05-30-2013, 12:56 AM   #7
AXV
Where do you suggest I connect the red/blue wire? I'm having trouble with this one. I already swapped the green w/ white stripe to the other plug so that one should be good.
Old 05-30-2013, 12:59 AM   #8
KiLLeR2001
Trader Rating: (46)
Just find a wire in the radio harness that shows 12V when you have the key to IGN ON. only. I'm not sure exactly which one, but if you have a test light you can narrow it down quickly.
Old 05-30-2013, 01:01 AM   #9
AXV
So find a wire that has 12v when it is IGN on and 0v when key is out?
And the wire to ground is the red/orange stripe one am I correct? This install is giving me a massive headache. All the write ups have broken links for picture and the explanation is at many times very vague.
Old 05-30-2013, 01:41 AM   #10
KiLLeR2001
Trader Rating: (46)
Yes. 0V when key is out. 0V when key is turned to ACC. and 12V when key is turned to IGN ON.
Yes.
Old 05-30-2013, 08:52 AM   #11
AXV
Hmm alright I will try again. All the guides say to connect to ACC
Old 05-30-2013, 04:36 PM   #12
AXV
Can someone help me identify a wire that is IGN ON? I've grounded the red/orange stripe wire but the damn thing still isn't working.
