1993 300zx TT stuborn missfire
A friend and I recently picked up a 93 twinturbo. This is a current list of what has been done to the car thus far:
Battery Spark Plugs UIM Gasket Injectors PTU Ignition Fuel Filter Clutch Slave Cyl Clutch Cables Clutch Master Cyl Compression test confirmed 170+ each cylinder. Grounding kit At this time, Cylinder 5 will not fire. We have used a test plug and confirmed that there is spark. We have checked the voltage to each line. the plug is wet with gas when removed, we have swapped the coil pack with a cylinder that is for sure firing. The next step we are about to take is to replace the entire wiring harness just to eliminate that as a possibility but wanted to check on here to see if anyone else has experienced anything like this and what possible fixes you guys can offer. Any help is appreciated. Thanks in advance. |
sorta
I remember working on a few of them and the coil pack harnesses were always brittle and had cracks as well as the coil packs themselves were always needing to be replaced like in a ca18det engine. New injectors don't always mean 100% ... they can be stuck
CA18 is the only way to go! ![]() |
We swamped the coil pack for cylinder 1 which is 100% for sure working. and still got nothing although with a test plug running off of cylinder 5's coil pack and - we got spark. We also replaced the plug in that cylinder yesterday and its still not firing.
![]() Join Date: Nov 2005
Check compression on that cylinder. I had a problem exactly like this. Turned out compression was 90psi on that cylinder. Bye bye VG30, hello 1JZ...
Injectors are from advance auto parts - and the compression check has been done - 170+ on each cylinder.
Hopefully we do not have to replace the injectors - that was not a fun job removing the intake. |
Why don't you put a noid light on the injector clip to see if it's even getting signal?
