![]() when i try to start my car the starter makes a buzzing noise and it doesnt start before i had to hit my starter with a hammer to get it to start now it doesnt start at all and it makes a buzzing noise? Please help do I need a new starter?
![]() Join Date: Apr 2011
![]() Feedback Score: 19 reviews
Battery might not have enough amps to turn the starter
...U can try using a different battery. make sure to check the voltage on the Alternator to make sure its charging you battery if you get it started . Should be a little over 13v wen charging If Car starts with new battery, and alternator is charging. Than you might have a bad battery
"before i had to hit my starter with a hammer to get it to start " your answer to your own question. If everything works in your car such as lights, horn, radio etc then it's probably not your battery. Get a starter.
