Old 07-15-2013, 12:52 PM   #1
Zumin
Zumin is an unknown quantity at this point
Kouki SE sunroof, wet floor board
I have a 1997 SE with sunroof. I've tried searching, but I get nothing but the usual "check your heater core" etc, well the smell isn't sweet and it's right in my passenger footwell. I don't notice this until I lifted up my factory floor mats and noticed the carpet was soaked. I'm wondering if the sunroof has a drain? Possible runs down the A pillar and down the passenger kick panel? Could it be the condensation overflow drain in the AC is just clogged?
I'm not sure if the s14 is prone to any of these, I know all chassis are different, so I'm trying to keep from chasing dead ends.
Zumin is offline   Reply With Quote
Old 07-15-2013, 01:46 PM   #2
Agamemnon
Agamemnon's Avatar
Yes. There are drain tubes on all 4 corners of the sunroof assembly that follow the a and c pillars. It is possible that they can get clogged or dislodge from sunroof drip rails.
I've never heard of AC condensation building up enough to leak into the cabin, but I suppose it's possible. I believe the AC box drains to the engine bay through a hard plastic spout.
Old 07-15-2013, 01:52 PM   #3
Zumin
I've heard other cars that can get it clogged as well from AC condensation.
But, ill check the water coming from the a pillar, the Trans tunnel isn't wet. The water seems to be in the middle of the floor
Old 07-15-2013, 02:01 PM   #4
jr_ss
The only reason the AC condensate would back up into the cabin is because of a clogged drain.
Most likely a missing floor grommet or the sunroof drains.
Old 07-15-2013, 02:30 PM   #5
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
thats what i was thinkin...
i would lean more towards the a/c condensation drain being clogged rather than the sunroof drains...
compare how ofter water gets in the sunroof channels vs how often you use the a/c.... i would check the ac drain first
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 07-15-2013, 02:03 PM   #6
Zumin
I'll check those.
Not what I want to deal with right now, trying to get this thing turboed
Old 07-15-2013, 02:34 PM   #7
Zumin
i live in and around the rainiest city in the US. (5 feet a year lol)
but also, its HUMID as hell. so AC is also on 24/7 when driving. but theres always a lot of condensation leaking from the car when the AC is on, so i kinda doubt its clogged.
Old 07-15-2013, 03:12 PM   #8
sleepyS14se
jesus christ what city are you in? lol
sounds like a good area for sliding around in stock ka pwrd 240s.ha
Old 07-15-2013, 03:01 PM   #9
jr_ss
Then you most likely have a floor pan grommet missing or damaged that's causing that amount of water to leak in.
I'd pull up the wiper cowling area as well and see if you can find any debris that would cause those drains to back up as well. This is where your fresh air intake is and there are ways for it to back up and then dump down into your blower motor assembly and leak out.
Old 07-15-2013, 03:42 PM   #10
Zumin
Mobile Alabama. yes, it rains often, and heavily
Old 07-15-2013, 09:39 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You sure it didnt leak down from the window being slightly cracked open? Check the sunroof drain, sometimes nipple for the hose have a tendency to break off from time to time. Also, does the back seat floor seem wet too? S14s are notorious leaking around the rear side windows and into the interior.
CLICK HERE!!!
Old 07-15-2013, 09:40 PM   #12
Zumin
All windows have been removed and reinstalled during paint job. I did leave the sunroom popped up during a rain about 1 month ago.. Only on passenger footwell
Old 07-15-2013, 09:47 PM   #13
fliprayzin240sx
Well since you said all glasses was removed and replaced, I'd re-inspect the windshield and make sure its not seeping from a bad seal.
CLICK HERE!!!
Old 07-15-2013, 09:52 PM   #14
Zumin
I thought about that, but I wasn't able to feel any wet sound deadening on the fire wall... I also hosed the car down
Old 07-16-2013, 12:36 AM   #15
Zumin
This was my drive to work on Friday ImageUploadedByTapatalk1373956574.385748.jpg
Old 07-16-2013, 11:14 AM   #16
sleepyS14se
omg you weren't lying about the rain wow man...with the said weather conditions i can see why your floor is wet...lol
Old 07-16-2013, 12:53 PM   #17
fliprayzin240sx
Double checked your window seals to make sure they're all snug on the glass? I got a gap on mine right by the side mirror area.
CLICK HERE!!!
Old 07-16-2013, 12:54 PM   #18
Zumin
I'll check
Old 07-16-2013, 04:26 PM   #19
Link
Link is an unknown quantity at this point
my sunroof on my s13 leaks pretty bad (not anymore because i duct taped it shut haha) but when it did, and the day after was really hot, the leftover moisture on my carpet would make it pretty humid and gross in my car. damn seals -__-
also, i noticed it's caused by the rusting of the metal right at the back of the sunroof. the rust chips off and clogs the drain tubes. really sucks right when i start driving, the first light i stop at i get a nice stream down my back lol
Link is offline   Reply With Quote
Old 07-19-2013, 04:01 AM   #20
ronny.jpn
ronny.jpn's Avatar
ronny.jpn is an unknown quantity at this point
I hate my sunroof. I also live in Mobile.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
ronny.jpn is offline   Reply With Quote
