![]() Join Date: Nov 2007
![]() So i have problem, i wired the injector and rpm together to the avc-r, which is a purple wire. Once i did this,
![]() Join Date: Aug 2011
Let me explain.
Rpm sensor is a somewhat passive component, nothing wrong there. However, injectors are directly connected to your battery on one side, and to your ECU on the other side. So if you are lucky you may only have killed your battery or some wires. If you are not, that is going to cost you quite a bit : injector drivers in the ecu (4 big power transistors and maybe the circuitry), injectors. Check your ECU first for burn marks. |
You could check the dropping resistors too, that may be why injectors arent firing. They should be around 6 or 12ohms each, cant remember exactly . disconnect it and check with an ohmmeter.
edit: check injectors too (disconnect them before). They should be around 3 ohms each. Last edited by Croustibat; 08-12-2013 at 11:34 AM.. |
If you still have no fuel you can check your fuel pump and fuel pump fuse ...
removing the injector ramp and turning the CAS manually should make the injectors fire . If they dont, you have a fueling problem. Testing the fuel pump is easy, testing injectors is a bit tricky; you need to ground the wire that comes out of the dropping resistor to open each of them. You could ground them directly (careful, the second pin has 12V) but dont keep it for long, just connect to ground, see if it sprays fuel, disconnect, or you can fry them. If the pump primes and injector fires, it can be ECU, CAS or wiring ... but if you have sparks, it is not the CAS. |
So I've got the car idleing now, not sure wha what I did to achieve this, but it's a rough idle like a cilyder not fireing. So what I've done so far... When the car was idleing I've pulled off one injector clip at a time to see if it get better or worse. No luck there, and the same with the coil packs.
Tags |
help needed |
