Old 09-03-2013, 09:52 AM   #1
kidwithjdmstuff
kidwithjdmstuff's Avatar
kidwithjdmstuff is an unknown quantity at this point
Rough idle and feels like it has no power
Sup guys,
i just recently bought a 240sx 92 Hatchback K24DE motor DOHC.
Car runs and everything is in good running conditions. I just recently did full tune up. Car is running rough still and it feels like it has no power. When i drive it it struggles to go up to 4000 rpm. it does not show me a check engine light. Every time i am on a complete stop the car turns off.
Any suggestions would be appreciate it.
Things that i have done:
Oil Change 10-40.
Fuel Filter and Hoses.
NGK Sparkplugs V-Power
I cleaned the MAF sensor.
Lukas fuel injector cleaner.
kidwithjdmstuff is offline   Reply With Quote
Old 09-03-2013, 04:31 PM   #2
MrMigs
MrMigs's Avatar
MrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond repute
Send a message via ICQ to MrMigs Send a message via AIM to MrMigs
Does it sound like it's not firing all 4 cylinders? Could be a dead fuel injector.
Also, might have to check ignition timing.
Just some common things.
Was it running fine before you did the tune up?
Drifting is just a compromise between you and your car.
MrMigs is offline   Reply With Quote
Old 09-03-2013, 05:23 PM   #3
kidwithjdmstuff
Thanks, I will have to change the injectors and timing. Yes the guy said it was running fine till this happened. He said that it would come and go, and this time it just runs rough now thanks.
