Old 05-14-2004, 09:25 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Exclamation Please Troubleshoot: Detonation
I have a SR w/ stock injectors, walbro fuel pump, greddy r spec front mount, gt spec exhaust. When i adjust the boost the car will detonate at a higher rpms, car is fine on stock boost.
A few weeks ago my fuel pump fuse blew i replaced it and the pump's buzzing noise grew way louder. I don't know how that would effect it because stock boost runs fine. Car only detonates when boost is changed. Im using greddy profec b spec 2.
If anyone has any information on what might be the issue for this, please post any solutions/causes.
What i have on my mind now is Bad injectors or badly gapped plugs, bad fuel pump- those are the only things that i can think of.
sepulchral is offline   Reply With Quote
Old 05-14-2004, 10:39 PM   #2
240eggsx
240eggsx is an unknown quantity at this point
Send a message via AIM to 240eggsx
Retard your timing a bit.
240eggsx is offline   Reply With Quote
Old 05-14-2004, 10:55 PM   #3
sepulchral
any more suggestions
Old 05-15-2004, 12:48 AM   #4
Turbozx
Turbozx's Avatar
Turbozx is an unknown quantity at this point
Check all the basics first.
plug gaps and condition
timing
fuel pressure
TPS
How high a boost does the detonation begin at?
91 Z32 TT, 92 Z32 TT, 90 240 LSX, 09 GT-R, 18 Honda Ridgeline
Turbozx is offline   Reply With Quote
Old 05-15-2004, 07:13 AM   #5
sepulchral
0.8 bar to 1.0 bar (12-15lbs)
thing is it used to boost and run that perfectly so something must have happened
Old 05-15-2004, 10:10 AM   #6
Var
Var's Avatar
Send a message via AIM to Var
carbon buildup? makes higher compression could be caused from running rich > upgraded fuel pump with no fuel controller.
Hi
Old 05-16-2004, 12:40 AM   #7
sepulchral
sd
topdssdddddddddddddddddddddddddd
