Old 11-11-2001, 12:03 PM   #1
MingMing
MingMing is an unknown quantity at this point
Send a message via ICQ to MingMing
hii, i juz had a question about doing peels in rwd cars, cuz i see all those really nice peels where the car's totally stationary, and i was wondering how ppl did that
cuz if u use the brake, it applies pressure to all 4 wheels rite?
and if u use the e-brake, it sonly the rear wheels, so how can they get the front ones not to move while burning up the back ones?
MingMing is offline   Reply With Quote
Old 11-11-2001, 12:32 PM   #2
Zexel
Zexel is an unknown quantity at this point
power braking...that's what it's called.  with a stick, I've always wondered how to keep it stationary like you're talking.  but my friends Dakota R/T could power brake for days.  no joke.  but I'm not sure, the only way to find out is the try it.  I mean just push the brake and punch the throttle.  or, you could throw it in neutral, rev it quite a ways, and hit it down to drive (for auto's), but I don't know how stationary it would stay.
Zexel is offline   Reply With Quote
Old 11-11-2001, 12:40 PM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Rev the engine up to like 5000 rpms (in first gear)
Dump the clutch
Slam on the brakes
S13Grl is offline   Reply With Quote
Old 11-11-2001, 02:12 PM   #4
Guest
Posts: n/a
yea you rev to max torque (i think its a little lower s13 girl) somewhere in the 3000 to 4000rpm range.  then while in 1st gear dump the cluth as fast as you can.  i wouldnt recomend putting the brakes cause then the wheels stop spinning.  you probably wont be stationary for long.  you need a s&^t load of torque to do that.  anywho just keep the rpms in the same spot at max torque and you should be ok.  i did it with my moms jetta and i stayed put for like 3sec and shes only got 127ft-lbs of torque
Old 11-11-2001, 02:16 PM   #5
silvia240
silvia240's Avatar
silvia240 is an unknown quantity at this point
i think the guy is asking how you do a burnout
silvia240 is offline   Reply With Quote
Old 11-11-2001, 02:20 PM   #6
Guest
Posts: n/a
i think thast what were telling him what to do
Old 11-11-2001, 02:33 PM   #7
chickenmanq
chickenmanq is an unknown quantity at this point
Yeah dude, drop the clutch, peel out, but before you start catching and go forward, hit the brakes.  70% of your braking force is on the front wheels.  You don't need to stomp the brakes.  Just enough to keep you from going forward, so you don't melt off all your rear pads. or shoes in my case.
chickenmanq is offline   Reply With Quote
Old 11-11-2001, 02:38 PM   #8
Guest
Posts: n/a
oh my bad didnt know that much of the force was in the front
Old 11-11-2001, 02:42 PM   #9
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
can someone explain dropping the clutch, somebody told me to put the clutch in, but i thought it was letting off the clutch.
BlankFlip is offline   Reply With Quote
Old 11-11-2001, 02:43 PM   #10
Guest
Posts: n/a
dumping the clutch is letting go of the clutch
Old 11-11-2001, 02:47 PM   #11
BlankFlip
BlankFlip's Avatar
k, that's what i always thought, cuz it didn't make sense to put the clutch in. maybe the guy misunderstood me when i talked to him about peeling out.
Old 11-11-2001, 04:20 PM   #12
antigrind
antigrind is an unknown quantity at this point
this i feel is the bast way to peel out in a 240. turn the wheel rev to 4000 and dump it. she will peel out like an animal dont let off till about 6000 then bang 2nd and ride it out.
         craig
antigrind is offline   Reply With Quote
Old 11-11-2001, 04:48 PM   #13
KoukiS14
KoukiS14's Avatar
KoukiS14 is an unknown quantity at this point
Send a message via ICQ to KoukiS14 Send a message via AIM to KoukiS14 Send a message via Yahoo to KoukiS14
With sasquatch sized feet like mine, I just use my right foot to hold the brake AND apply pressure to the gas pedal. . then I rev and dump the clutch... can peel out for awhile. =)
KoukiS14 is offline   Reply With Quote
Old 11-11-2001, 07:36 PM   #14
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from antigrind on 7:20 pm on Nov. 11, 2001
craig
</td></tr></table><span id='postcolor'>
ya make shure you pint the wheels strate at a telephone pole &nbsp;:o
my240likenoother is offline   Reply With Quote
Old 11-11-2001, 08:23 PM   #15
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from BlankFlip on 1:47 pm on Nov. 11, 2001
Don't you clutch in when you let go of the clutch? Or does clutch in mean pressing the clutch pedal down?
Old 11-11-2001, 10:04 PM   #16
Guest
Posts: n/a
really bad for your rear brakes...
Old 11-13-2001, 08:18 PM   #17
konkman
konkman is an unknown quantity at this point
Yeah, your brakes will take it. &nbsp;But what about your tires. &nbsp;I wouldn't dare try to put on a smoke show with new expensive rubber. &nbsp;
But hey, my money tree is starting to sprout. &nbsp;
konkman is offline   Reply With Quote
Old 11-13-2001, 08:27 PM   #18
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
i think i need new rear brakes again........
i think my rear pads are gone again, i put them in, in July...... i should check them soon...... they are making a horrible noise again when i go in reverse
drifterx is offline   Reply With Quote
Old 11-13-2001, 08:57 PM   #19
konkman
Sounds like you have a squeeler.
I traded cars with my dad for a couple weeks so I could use his truck for some work I was doing (I don't live with my dad). &nbsp;I get it back and the brakes are squeeling like mad. &nbsp;It started the day I gave it to him. He didn't call me, didn't get it checked and when I finally took a look at it. &nbsp;I was at like 1% in the front (if that's possible). &nbsp;I had no brake left. &nbsp;Smart guy.
Old 11-14-2001, 08:08 AM   #20
drifterx
drifterx's Avatar
i changed all the pads in july and put in new disc in the front.... i think it is about time i change the rear disc (####, but i'll wait)
but i think i killed the rear brake pads from doing brake stands....
Old 11-14-2001, 08:18 AM   #21
TRM02
TRM02 is an unknown quantity at this point
Send a message via ICQ to TRM02
Has anyone put a &quot;line lock&quot; I know some supra guy that have done this...Let me explain what a line lock is. Basiclly you have a button that will apply the front brakes only keeping the car in one spot so you can do your burn out to warm up the tires. you can get these kits at almost any musles car shop the Mustang and F-body guys have been useing these for ever.
TRM02 is offline   Reply With Quote
Old 11-14-2001, 08:35 AM   #22
180sx
180sx is an unknown quantity at this point
Just do a 300zx brake upgrade, guaranteed to keep from going anywhere.
180sx is offline   Reply With Quote
Old 11-14-2001, 09:31 AM   #23
S13Grl
Married to the Mob
S13Grl's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from drifterx on 9:27 pm on Nov. 13, 2001
I have the same problem. I thought it was that old lady that I ran over stuck by my cat-back, but it turns out it's the brakes. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Just kidding.
Anyway, I need to replace my rear pads. The weather is horrible out here, and I was really looking forward to doing it myself, but I guess it's gonna have to be a shop. Sometime soon...
Old 11-14-2001, 12:16 PM   #24
TRM02
you guys should look into the line lock it will save money one brake pads
Old 11-14-2001, 07:01 PM   #25
Guest
Posts: n/a
just rewire your E-Brake to the front....if that is possible hehe
Old 11-14-2001, 07:27 PM   #26
mistert
Pearl White Mike
mistert is an unknown quantity at this point
Send a message via ICQ to mistert Send a message via AIM to mistert
its not that difficult guys. to put it in simple terms for the original questions askers who didnt seem to get it:
1. press in the clutch pedal with your left foot all the way
2. ease onto the guess until the tach hits in the 4500-5000 range (this isnt your max torque, but unless you want to kill your drivetrain, overdo it and release the pedal some when you dump the clutch)
3. now as fast as you can, pull your foot off the gas pedal and let the clutch go, while going to WOT (wide open throttle)
if you have an auto...get a manual. trying to burnout with an automatic is retarded. if you have a torque monster and dont mind hurting your brakes too much, or have a line lock, you can select first and punch it. however, if you try to rev it in neutral and put it into drive with or without gas while the engine still has any significant rev on it, you WILL find yourself picking up hundreds of little chunks of metal from underneith your car.
oh well. that'd be a good excuse to go ahead and get that manual transmission you really wish you had
mistert is offline   Reply With Quote
Old 11-14-2001, 09:00 PM   #27
MingMing
wait, first u said take it to 4k-5k rpms
and then as fast as i could, unclutch and take foot off gas pedal, while at WOT, that woul dhave to mean that i'd hafta floor it first, and then take both off as fast as possible?
or do u mean take foot OFF the clutch but press harder ON the gas?
Old 11-14-2001, 11:06 PM   #28
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
yeah...don't take your foot off the gas...otherwise the revving would be pointless.
And mistert, max torque does occur between 4500 and 5000...4800 to be exact.
LanceS13 is offline   Reply With Quote
Old 11-15-2001, 12:35 AM   #29
S13Grl
Married to the Mob
S13Grl's Avatar
That's gonna launch you, not let you stay in place and burn rubber.
Old 11-15-2001, 09:52 AM   #30
LanceS13
AutoX Junkie
it's not gonna launch you if you break traction...you normally launch down around 3000-3500, before max torque. &nbsp;Just dump it at 5K and put about half pressure on the breaks.
