Old 09-30-2013, 12:28 PM   #1
claytoncallihan
claytoncallihan is an unknown quantity at this point
Manual tranny fluid/fill questions
have to reverse light sensor and another sensor so gonna just put new fluid in while im at it, was wondering a few things:
anyone know the exact amount of oil to put in trans for a s13?
I was thinking just drain, replace things (sensors), and unplug the fill plug and then pour in fluid thru the shifter and when it starts coming out the fill plug, should be full right? never done it on a 240, but seems easy enough right? or am i missing something?
also, what oil do you guys recommend? want to put some good stuff in there and keep this puppy goin
claytoncallihan is offline   Reply With Quote
Old 09-30-2013, 12:45 PM   #2
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Good plan. Make sure car is level. Amsoil or redline is good. 75w90 or mt90. I'd recommend Amsoil however. Make sure the gear oil is gl4 only
Ilya is offline   Reply With Quote
Old 09-30-2013, 01:08 PM   #3
claytoncallihan
Thank you sir. sounds good. Ill post back if any troubles arise haha!
Old 09-30-2013, 01:11 PM   #4
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
yep, fill til it pours out. if you google the fsm it will give you an exact quantity
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 09-30-2013, 02:32 PM   #5
MrMigs
MrMigs's Avatar
MrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond repute
Send a message via ICQ to MrMigs Send a message via AIM to MrMigs
You'll need to buy 3 quarts. The tranny holds something like 2.5 qts, but yea... as for filling, do as the guy above said.
Drifting is just a compromise between you and your car.
MrMigs is offline   Reply With Quote
Old 09-30-2013, 03:02 PM   #6
teh smithers
teh smithers's Avatar
teh smithers is an unknown quantity at this point
I just used Amsoil and my shitty transmission feels noticeably less shitty. Definitely hyped about that.
As stated above, buy 3 quarts of GL4 ONLY.
teh smithers is offline   Reply With Quote
Old 09-30-2013, 03:33 PM   #7
claytoncallihan
Awesome guys, thanks for the replies. This is why I love zilvia
Old 09-30-2013, 04:19 PM   #8
Tom N
Tom N is an unknown quantity at this point
Amsoil manual trans oil. Dont get the amsoil 75w90 gear oil as its gl5. Make sure its the amsoil manual transmission oil.
This AMSOIL Manual Transmission & Transaxle Gear Lube 75W-90
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 09-30-2013, 04:30 PM   #9
claytoncallihan
Ahh! Was lookin for a direct page for it! THANK YOU!
Old 10-01-2013, 08:36 AM   #10
Mikester
Mikester's Avatar
You can also attach a long hose to a funnel and fill it from the engine bay if you don't feel like pulling the shifter.
Old 10-01-2013, 09:01 AM   #11
mechanicalmoron
Or, you can do the same, but sit in the driver seat and fill it with the hose running down the shifter hole in the body.
If you have a steady hand.
Ended up doing that after I couldn't get the shifter off....
Old 10-01-2013, 08:41 AM   #12
kpnasty
kpnasty's Avatar
kpnasty is an unknown quantity at this point
i love how you can fill through the shifter, so easy. was the same on my miata. idk much about these trans' but the yata was extremely picky about what fluid was in it. heard good things about amsoil anyway.
kpnasty is offline   Reply With Quote
Old 10-01-2013, 08:45 AM   #13
Tom N
With a gear oil pump all you have to do is pump it out of the bottle and into the tyranny threw the fill hole. Takes less than 5 minutes.
Old 10-01-2013, 09:17 AM   #14
jr_ss
If you have a compressor, drill a hole in the top of your fluid bottle, insert a long hose into the bottle, through the spout, to the bottom and use an air pressure source in tye drilled hole to force the fluid up through the tube and into your transmission.
Old 10-01-2013, 09:29 AM   #15
Mikester
Mikester's Avatar
...says the guy who taught me how easy it is to just fill from the bay...
Of course, the difference between these guys' trannies and ours being the lack of accessibility to the top
Old 10-01-2013, 10:34 AM   #16
jr_ss
I had to use the above mentioned method to fill the front and rear diffs and the the transfer case in my Xterra. Worked beautifully.
Old 10-01-2013, 11:44 AM   #17
claytoncallihan
Seems easier to just do it from the shifter haha.
Old 10-01-2013, 12:00 PM   #18
mechanicalmoron
It can be a bitch to reach the two forward bolts, especially if the exhaust is hot. And then when I got them all, I couldn't pop the thing off, without doing things that made me sure there would be a large mess. I just poured in the normal hole, and it went fine.
The pouring will be easier, but getting READY to pour, will not be.
As far as hoses go, you can just use a bike inner tube, and a funnel. Or you can get a pump that looks like a big syringe that holds a quart, for like 15 bucks. That's probably the best, easiest way.
^^Yea until you spill gear oil in your car somewhere and it wreaks for several weeks
You don't like gear oil? Smells like sweet onion salad dressing.
Old 10-01-2013, 12:02 PM   #19
jr_ss
For the people running better transmissions than the KA/SR that simply doesn't work.
Old 10-01-2013, 12:02 PM   #20
Mikester
Mikester's Avatar
From the engine bay is easy peasy- doesn't require the bezel, shifter & sound/dust boots to be removed (along with any grounds for stereo, gauges etc).
Pump/aspirator is perfect for the diff.
Either way, pretty much every method is now covered in this thread... Other than the 'take it to Jiffy Lube & have some minimum wage DB do it' method haha!
Old 10-01-2013, 12:11 PM   #21
claytoncallihan
I gotcha. Ill debate in my head for a bit haha
Old 10-01-2013, 12:31 PM   #22
Johannes
Johannes's Avatar
Johannes is an unknown quantity at this point
I'm surprised at how no one has mentioned that you can simply just remove the shifter lever by removing the internal snap ring on there using snap ring pliers or needle nose. You just need to remove center console, rubber boot, and the boot that's on the shifter assy., and you'll see the snap ring.
^that's of course, only for people who has stock shifter.
Johannes is offline   Reply With Quote
Old 10-01-2013, 12:49 PM   #23
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
I use Motul Gear 300 in the diff and tranny, it is good stuff. Looks like you have got your answers but make sure to get a cool fluid pump thingy and fill your tranny up until it drips out.
Also, we tend to teflon tape our drain plugs but this is optional.
om3ga is offline   Reply With Quote
Old 10-01-2013, 01:29 PM   #24
claytoncallihan
Definitely stock as crap haha
Gotcha.
Old 10-01-2013, 02:18 PM   #25
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Do NOT pour fluid into the shifter if your fill plug on the side of the trans is out. It will pour right back out of the fill plug and get all over the place. (Ask how I know).
Old 10-01-2013, 02:20 PM   #26
claytoncallihan
Wouldnt it only pour out once its full?
Old 10-01-2013, 02:36 PM   #27
brndck
brndck's Avatar
Negative. If you pour it IN the shifter it has to go PAST the fill plug to get down into the guts of the trans. I tried it once before and wasted almost a full quart of mt90 straight onto my driveway.
Old 10-01-2013, 02:58 PM   #28
claytoncallihan
ahhhh gotcha. good to know!
Old 10-01-2013, 03:33 PM   #29
brndck
brndck's Avatar
Another thing, sit the cans or bottles of fresh fluid out in the sun for a bit before you start. If the fluid is warm it flows more easily.
