NEED GONE GARAGE SALE> SR,S13,S14,KA Parts All parts need to go!
I sold my car and most of my parts to build nissan's. no trades, all offers welcome but please do not think I will give you anything that has value and I can sell on ebay. I will give you guys first dibs then off to ebay and craigslist I go. I will only ship small items at buyers expense, large items are for local pick up or buyer arranges all shipping arrangements.
If it's something you see in a bin and it's not priced you can have it plus shipping. don't waste my time, if you have no money to buy do not PM me. Thanks for looking! S13 one piece Driveshaft - "SOLD" ![]() Tomei - 251001 Z32 Airflow Adapter used for about 4,000 miles. SOLD ![]() ![]() Apexi Dual Funnel Power Intake - used for about 7,000 miles - 507-N009 - 75.00 ![]() ![]() S13 injector grommets (new) - 5.00, S13 JDM Clutch Master Cylinder with nissan rebuild kit - 30.00, NGK 6988 plugs 20.00 (new), stock shift knob - SOLD, S14 SR oil filter adapter - 5.00, Nissan gaskets 1.00 each, Axle nuts 1.00 each. ![]() Gasket for s14 SR - 25.00 ![]() S14 Cam gear 5.00, Nissan assembly silicone SOLD, Gaskets 2.00 each, sr oil cap 2.00 ![]() S13 sr fan shroud and clutch fan. Has a cut out for US fitment keeping ac shroud SOLD, clutch fan 10.00. ![]() ![]() ![]() S13 power steering resivoir (steel)- 15.00, plastic SOLD ![]() ![]() S13 shifter rubber base SOLD, Elbow 90deg 10.00 ?" Ill check I think its 2.5 or 3", ![]() ![]() S13 intake pipe - 35.00 rubber 10.00 ![]() ![]() S14 HKS hot pipe, steel, rusty but can easily be blated and painted. 20.00 ![]() Injen Z32 cone filter and adapter - 15.00 very used ![]() SR through out bearings - 25.00 each. Bearing are good, stock shifter - SOLD ![]() S13 front plate holder 5.00, cusco 25.00 ![]() ![]() S14 sr coil pack cover - 8.00 ![]() SR oil pan 10.00 ![]() Nissan 7 layer gasket used 7,000 miles - 10.00 ![]() Turbo outlet - SOLD,S14- "i think" sr exhaust heat shield 5.00 ![]() ![]() S13 5 speed cross member - SOLD ![]() S14 sr cross over tube - 5.00 ![]() S14 sr iac valve (works fine) - 25.00 ![]() S14 sr upper intake - 10.00 ![]() sr20det BC +1mm exhaust valves 2 sets - 60.00each set ![]() S14 sr head with stock springs - 60.00, s14 sr stock cams - 20.00 ![]() ![]() BDL Billet SR timing cap - 40.00 ![]() SR20 stock pulley's ![]() random plugs - 10ea. ![]() ![]() 350z pedal covers 10 pair ![]() speedo sensors - 20.00 ![]() ![]() KA auto ecu - 10.00 ![]() blow off valves - 20.00ea ![]() Last edited by jorgezee1; 10-15-2013 at 10:00 AM.. |
As requested here are the rest of the item I have for sale.
SR/KA Maf adapter - 10.00 ![]() KA MAF very clean - SOLD ![]() ![]() S13SR Turbo outlet 5.00, S13SR temp sensor adapter, S14SR turbo outlet 5.00, S14SR water neck 5.00 ![]() 92 240sx ac fan ![]() z32 rear e brakes only 5.00 ![]() One nismo motor mount 5.00 S13 KA A/C lines 20.00 ![]() S13 radio adapter kit 10.00 ![]() Blitz DC II controller box and boost gauge 250.00 obo for the set, gauge works perfectly but the chrome around it is starting to come up. ![]() Last edited by jorgezee1; 10-16-2013 at 11:17 PM.. |
#15 |
#22 |
#25 | |
Sorry guys I only have s13 speed sensors. They were pulled from running s13's that had a swap done. I'm not sure on the milage. All parts are "as is" if you buy them and they do not work properly I will refund you the money upon return or trade for other items. Item that are junk I will through away no point in listing them. I just want to sell off the stuff I know you guys can use on your builds. Thanks, Jorge |
