1996 Mazda Miata (Extremely Clean)
Asking $3999.
Located in Lancaster, PA 1996 Mazda MX-5 Miata 1.8L Engine w/ 5 Speed Manual Transmission Red Exterior w/ Black Cloth Interior & Black Top 108,000 Miles The following parts listed are newly installed to the vehicle. Convertible Top Timing Belt Water Pump Radiator Battery Clutch & Pressure Plate Pilot & Throw-out Bearing Rear Brake Calipers Rear Brake Pads & Rotors Front Brake Pads Brake Fluid Oil Change Clutch Slave Cylinder Clutch Fluid Transmission & Differential Fluid Valve Cover Gasket Spark Plugs & Wires Front Passenger Side Wheel Hub Assembly Rear Passenger Side Wheel Bearing Passenger Side Axle Reverse Light Switch Sway Bar End Links Head-unit w/ Aux Port Front Lip Spoiler Lug-nuts Short Antenna BroSpeed Cat-back Exhaust installed by previous owner AC & Heat work great The interior is very clean and was just shampooed. The paint is in almost perfect condition and was just buffed, polished, and waxed. There is no rust on this car as well. You will not find a more mechanically solid car. Serious inquiries only. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by food7373; 12-07-2013 at 12:49 PM.. |
