Old 12-22-2013, 11:02 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
HKS, RacePak, Megan Racing, Votion, TONS MORE-OVER 100 PARTS!*!*!*!*!*
MAKE AN OFFER...WORST I CAN SAY IS NO!
HKS EVC VI Boost Controller
- BRAND NEW IN BOX!
- $550 (Retail: ~$700)
RacePak Vnet EFI Interface Module for AEM
- This allows you to hook up an AEM ecu to a RacePak cluster
- BRAND NEW IN BOX!
- $300 (Retail: ~$375)
Votion Liquid to Air Intercooler Kit (Custom order...not sold as a kit)
- Capable of supporting up to 1000+hp
- BRAND NEW IN BOX!
- Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler
- $750
SR Timing Chain Tensioner
- ~3k miles
- Perfect Shape
- $50
Cam Angle Sensor Gasket and O-ring
- Perfect Shape
- $5
Intake and Exhaust Cam Gear Bolts
- PERFECT SHAPE!
- $3 each
SR20 Head Bolts
- Used
- $15
KU Engineering Style S13 Intake Manifold
- Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1)
- $100
SR20 Upper Oil Pan - SOLD!
SR20 Oil Pump - SOLD!
SR20 Oil Screens (2 sets)
SR20 Rear Crank Case Cover (4)
SR20 Oil Block Galley w/ Sensor - SOLD!
SR Main Cap Girdle
- PERFECT SHAPE
- $15 each
SR Coolant Tubes - $20
SR Short Coolant Tubes - $5
SR Temp. Sensor Housing - $10
SR Thermostat Housing - $10
SR Coolant Inlet - $10
SR Coolant Complete Setup w/ Sensors - $45
OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- Valves - SOLD!
Springs - $25
Retainers - $15
Camshafts - $50
Gears - $10
SR20DET AAC Valve
- PERFECT SHAPE
- $30
S14 SR Valve Cover w/ Coil Pack Cover
- Perfect Shape
- $160
stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki)
- PERFECT SHAPE
- $50
S13 Non-ABS Driveshaft - Pick up only
- Used
- $90
S13 SR Transmision - Pick up only
- Roughly 30k miles
- PERFECT SHAPE
- $125
S13 SR Nismo Transmission Mount
- Used
- $60
S13 SR Bell Housing
- No cracks
- $40
S13 SR release bearing
- Good Condition
- $10
S13 SR Clutch Fork
- Perfect Shape
- $20
SR20 Timing Chain guide
- Perfect Shape
- $10
S13 SR Valve Cover Baffeling
- Great Shape
- $10
SR20 Coilpack Gaskets
- NEW
- $3 each
S13 SR20 Intake Gasket
- PERFECT SHAPE
- $10
S13 SR20 Valve Cover Gasket
- Perfect Shape
- $15
Injector Gasket O-rings
- Perfect Shape
- $3 each
SR20 Rear Main Seal
- New In Box
- $18
(8) SR20 Hydraulic Lifters
- Perfect Shape
- $5 each
Megan Racing SR T3/T4 Exhaust Manifold
- NEVER USED
- $90
SR OEM Exhaust Manifold
- Perfect Shape
- $40
SR20det Exhaust Gaskets (t3, T4, Exhaust mani)
- Perfect Shape
- $20
Crank Pulley Bolts (2)
-Perfect Shape
-$5
Transmission Mount Brackets
- Perfect Shape
- $15 each
Alternator Brackets
- Perfect Shape
- $20 each
Knock Sensor (4)...one doesn't have a sub-harness
- Perfect Shape
-$25 each (15 for the one without the sub-harness)
Godspeed Arm - $15
S13 Rear Links - $10 each
S13 Front Lower Control Arm - $30
(2) o2 Sensor Simulator
- one was touched with dirty hands, then I put on gloves
- NEW IN BOX
- $33 (each)
\/ \/ \/ 350Z PARTS \/ \/ \/
350z OEM Hatch w/ Glass
- Perfect Shape
- $300
350z OEM Hood
- Perfect Shape
- $250
350z OEM Fenders
- Perfect Shape
- $150
350z OEM CD009 Transmission Gears (I switched to OS Giken Gears)
- Perfect Shape -15k Miles
- $350
350z Master 1 1/16th
- Perfect Shape
- $45
350z Brake Booster
- Perfect Shape
- $100
350z Arms
- Perfect Shape
- $50
350z 03' tinted tail lights
- Great shape
- $75
These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request.
\/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/
OEM Air Box Setup
OEM Downpipe
OEM Full Exhaust
OEM Uppipe
OEM Turbo Heat shield
\/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/
Head (currently has valves, springs, retainers, and keepers but can remove if buy requests)
Rocker arms
Oil tubes in SR head
Intake and Exhaust cam gears
Valve Cover
EGR valve (in WORKING order)
distributer (in WORKING order)
Headers
Injectors w/ Fuel rail
Intake Manifold (perfect Condition w/ all connectors and hoses)
(3) Pistons
(3) Rods
Water Pump
Water Pump pulley
oil filter block
crank pulley
Coolant tubes
Coolant outlet
Lower Oil Pan
Oil Pan baffling
Timing chain tensioner
Flex Plate
Auto trans gasket
Alternator bracket
intake bracket
power steering bracket
ac bracket
Auto 200sx Engine Harness (completely uncut)
injector harness
tps (throttle position sensor)
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 12-22-2013, 11:46 PM   #2
sil15yaz
sil15yaz is an unknown quantity at this point
The evc 6 best price inc international shipping?
sil15yaz is offline   Reply With Quote
Old 12-25-2013, 02:13 PM   #3
cmts13
cmts13 is an unknown quantity at this point
interested in trans pm me
cmts13 is offline   Reply With Quote
Old 12-25-2013, 05:20 PM   #4
kaptin
kaptin is an unknown quantity at this point
any chance you have sr20 mount brackets? the part that bolts to the motor.
kaptin is offline   Reply With Quote
Old 12-25-2013, 06:03 PM   #5
silviadrag
silviadrag is an unknown quantity at this point
Still Have ThE Valve Cover Baffles Price Ship To Ny 11003
silviadrag is offline   Reply With Quote
Old 12-25-2013, 10:05 PM   #6
Kennybhybrid
Kennybhybrid's Avatar
Kennybhybrid is an unknown quantity at this point
Do you still have the sr20 trans? Interested if so
Kennybhybrid is offline   Reply With Quote
Old 12-27-2013, 05:00 PM   #7
applefrk15
applefrk15 is an unknown quantity at this point
i see 2 oil filter blocks, still have one of them?
applefrk15 is offline   Reply With Quote
Old 12-27-2013, 10:46 PM   #8
TheRealSy90
TheRealSy90's Avatar
How much for the sr20 rockers and rocker guides.
Such a good signature.
Old 01-02-2014, 08:46 AM   #9
Kennybhybrid
Trans still available?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
Old 01-06-2014, 10:50 AM   #10
stayclassy
stayclassy's Avatar
stayclassy is an unknown quantity at this point
interested in thermostat housing shipped to 18324
stayclassy is offline   Reply With Quote
Old 01-06-2014, 12:05 PM   #11
Jdm651
Jdm651 is an unknown quantity at this point
Sell coil pack cover?
Jdm651 is offline   Reply With Quote
