Old 01-03-2014, 06:19 PM   #1
red93vert
red93vert's Avatar
red93vert is an unknown quantity at this point
check engine light flashes
I was wondering if anyone has had this problem and if you knos the fix, I have a 1993 dual ka and I have no idea why but my check engine light flashes, it's not in the self diagnostics mode, when when I do the self diagnostics it shows there is no code saved, and it just seems to flash when under acceleration. Has anyone ever experienced this????? I need help plus my cars not passing smog
red93vert is offline   Reply With Quote
Old 01-04-2014, 01:29 AM   #2
Rambuck
Rambuck is an unknown quantity at this point
Not passing smog, yet no DTC set... Have all your self-tests passed? A cheap generic scan tool can reveal the status. I like the wireless XTool with iODB tool.
As for flashing... Seems to me like a transmission problem. Mine sets a DTC when it happens but there could be others that don't set. In any case, these won't prevent you from passing smog. They might interrupt the self test however... Probably an intermittent fault with the vehicle speed sensor.
Rambuck is offline   Reply With Quote
Old 01-04-2014, 02:14 AM   #3
Rambuck
I believe one that doesnt set a DTC is the speed sensor monitor (backup) sensor. But some others may exist. Do you have an AT? Is there an overdrive button on the shifter? If so, perform an AT self-diagnosis. It's tricky.
Warm up, turn off
Ignition to Acc
OD on
Shifter in park
Ign ON (don't start)
Does OD lamp come on?
Repeat if no.
If yes:
IGN off/IGN on (don't start)
Shift to Drive
OD off
IGN off/on
Wait 2 seconds
Shift to 2nd
OD on
shift to 1st
OD off
Press gas pedal fully and release
OD lamp should illuminate and flash several times. There's and order to the pulses. If one is longer than the rest, there is a problem.
Old 01-07-2014, 01:32 AM   #4
pancakes562
pancakes562's Avatar
pancakes562 is an unknown quantity at this point
Try unplugging your car overnight. It'll reset everything when you plug it back in. Might work?
pancakes562 is offline   Reply With Quote
Old 01-07-2014, 01:58 AM   #5
red93vert
red93vert's Avatar
Thanks guys, I figured out the problem
Old 01-07-2014, 03:01 AM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If its not on diagnostic mode and suddenly starts blinking while accelerating, that is usually the knock sensor.
CLICK HERE!!!
