Old 01-27-2014, 08:21 PM   #1
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
Talking 240sx Parts Sale EVERYTHING YOU CAN THINK OF!! GIANT LIST OF PARTS LOOK
ALL PURCHASES COME WITH INSURANCE, TRACKING INFORMATION, AND LEGITIMATE PACKAGING.
Some sellers are so terrible that is actually makes a difference to say that... Shitty isn't it?
Text me for questions, info, or ask if I have something you need.
TEXT ME PLEASE - 361-571-1026 DEAN
NEW PARTS TO THE LIST:
S13 Climate Control (Mint Condition) - $40 shipped
S13 Rear Side Marker Lights - $20 shipped ea $30 shipped for both
S13 Fuse Box Pigtails - $10 each shipped
S13 OEM E-Brake Cables (GOOD Condition, not stretched) - $60 shipped
S13 KA24DE Engine Harness Pigtails - PM me what you need $15 shipped each
-S13 License plate light assembly - $25 shipped
-S13 Window Amp - $25 shipped
-S13 Ash Tray - $25 shipped
-S13 Passenger Side Power Window Trim with switch - $25 shipped
-KA24DE Oil Cap - $20 shpped
-Driveshaft carrier bearing top half - $15 shipped
-S13 Hatchback Trunk Light - $15 shipped
-KA24DE Fuel Injector Caps - $15 shipped for 4
-S13 Door Handle Trim - $15 shipped
-240sx Gas Cap - $15 shipped
S13 Fuel Pump Harness Metal Cover - $15 shipped
S13 Pop-Up Headlight Motor Covers - $10 shipped per pair
S13 Gas Pedal Assembly - $20 shipped
KA24DE/E Oil Filter Block - $20 shipped
240sx steering shaft U-Joint w/ bolts - $25 shipped
240sx Power Steering Rack Brackets w/ bolts - $25 shipped
KA24DE Fuel Injector Bushings - $8 shipped for 4
KA24DE Cam Sprocket Bolts w/ washers - $10 shipped per pair
240sx Shock absorber cap - $5 shipped
240sx Hub Cap - $8 shipped
S14 OEM Diff Bushings - $10 shipped
KA24DE Oil Pump Drive, Key-way, and Bolt w/ washer - $15 shipped
S13 Passenger Side Kick Panel - $18 shipped
240sx Shifter - $20 shipped
240sx Radiator Hold Down Brackets - $15 shipped per pair
KA24DE Oil Filter Block Gasket OEM - $8 shipped
KA24DE Throttle Body Gasket - $5 Shipped
KA24DE Coolant Temp Sensor - $8 Shipped each
S13 Radiator Bushings - $10 shipped per pair
S13 89-90 Dash Connector Pigtail Chassis Side - $10 shipped
KA24DE Flywheel Bolts - $20 shipped for 6
T25 Turbo Inlet Gasket - $5 Shipped
KA24DE/E Throttle Position Sensor - $15 shipped
KA24DE Spark Plug Clips Perfect Condition - $15 for all 4 shipped
S13 Rear Side Marker Lights w/ harnesses - $15 shipped each
S13 Hatchback Trunk Trim - $20 picked up
S13 Front Crossmember - $60 picked up
IMG_0728 by Dean Chinowith, on Flickr
S13 Fusebox Bracket Engine Bay - $20 shipped
IMG_0729 by Dean Chinowith, on Flickr
S13 Power Window Glass - $20 Picked Up
IMG_0731 by Dean Chinowith, on Flickr
S13 Hatchback Tail Light Garnish - $20 picked up
IMG_0732 by Dean Chinowith, on Flickr
91-94 S13 Dash Harness Pigtail (Chassis Side) - $15 shipped
IMG_0733 by Dean Chinowith, on Flickr
KA24DE 5-Spd Transmission Gussets - $35 shipped (Only because they're heavy)
IMG_0737 by Dean Chinowith, on Flickr
S13 Hatchback Tail Lights - $80 shipped
IMG_0738 by Dean Chinowith, on Flickr
S13 E-Brake Cables in good shape - $45 shipped
240sx Throttle Cable - $30 shipped
S14 Auto Shifter Lock Cable - $15 shipped
IMG_0740 by Dean Chinowith, on Flickr
S13 Under Steering Wheel Dash Panel - $25 shipped
S13 Hatchback B-Pillar Exterior Trim L + R - $20 shipped
IMG_0747 by Dean Chinowith, on Flickr
-S14 OEM Rear Sway Bar - $60 plus shipping
-S14 OEM Suspension (great shape, 80,000 miles) - $40 plus shipping
- S13 Headlights Brackets - 40 shipped
IMG_0314 by Dean Chinowith, on Flickr
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
Old 01-31-2014, 12:20 AM   #2
drifter92
drifter92's Avatar
bump to the top
Old 02-01-2014, 07:22 PM   #3
drifter92
drifter92's Avatar
bump to the top
Old 02-05-2014, 10:34 PM   #4
drifter92
drifter92's Avatar
buuuuuuuuuuuuump
Old 02-06-2014, 10:27 PM   #5
boost infested
boost infested's Avatar
boost infested is on a distinguished road
Do you have the wiper pivots? pm me
boost infested is offline   Reply With Quote
Old 02-09-2014, 03:58 PM   #6
drifter92
drifter92's Avatar
Still lots Of parts
Old 02-09-2014, 04:17 PM   #7
Hooleeoh69
Hooleeoh69 is an unknown quantity at this point
S13 Passenger side window amp?
Hooleeoh69 is offline   Reply With Quote
Old 02-09-2014, 05:25 PM   #8
vietuser619
vietuser619's Avatar
vietuser619 is an unknown quantity at this point
S14:
Power Window Switch Trim right passenger side
+Door Handle Trim left side + right side
+center console
all shipped to san diego ca 92111
vietuser619 is offline   Reply With Quote
Old 02-13-2014, 10:15 PM   #9
drifter92
drifter92's Avatar
still have lots of parts for sale
Old 02-14-2014, 07:53 PM   #10
drifter92
drifter92's Avatar
bump to the top
Old 02-15-2014, 02:49 PM   #11
simpdt
simpdt is an unknown quantity at this point
s14 radio bezel?
simpdt is offline   Reply With Quote
Old 02-15-2014, 05:38 PM   #12
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
are you willing to ship the crossmember?
g2ic02 is offline   Reply With Quote
Old 02-18-2014, 12:06 AM   #13
drifter92
drifter92's Avatar
Old 02-19-2014, 12:02 AM   #14
drifter92
drifter92's Avatar
bump to the top
Old 02-22-2014, 02:34 PM   #15
drifter92
drifter92's Avatar
still have tons of parts to sell
Old 02-23-2014, 04:05 PM   #16
240sx-pat
240sx-pat is an unknown quantity at this point
Send a message via AIM to 240sx-pat Send a message via MSN to 240sx-pat
i neeed the front sway bar brackets please pm me
240sx-pat is offline   Reply With Quote
Old 02-25-2014, 10:20 PM   #17
drifter92
drifter92's Avatar
still have lots of parts to sell
Old 02-26-2014, 06:42 AM   #18
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Do you have the wiring that goes to the AC compressor and shit?
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 02-26-2014, 06:56 AM   #19
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
Do you have S13 riverside power window trim and switches?
Arrowking is offline   Reply With Quote
Old 02-27-2014, 07:03 PM   #20
bambina69
bambina69's Avatar
bambina69 is an unknown quantity at this point
Do you have zenki headlights for sale as well? Ship to CA
bambina69 is offline   Reply With Quote
Old 02-27-2014, 07:37 PM   #21
drifter92
drifter92's Avatar
no, yes, and no
Old 02-27-2014, 08:31 PM   #22
Arrowking
Arrowking's Avatar
Originally Posted by drifter92 View Post
no, yes, and no
Check your PMs!
Old 02-27-2014, 08:26 PM   #23
Theezy
Theezy is an unknown quantity at this point
do you also have the power steering wires to go along with the reservoir?
Theezy is offline   Reply With Quote
Old 02-27-2014, 08:27 PM   #24
bambina69
bambina69's Avatar
Yes to the headlights?
Old 02-27-2014, 10:54 PM   #25
kocampo1
kocampo1 is an unknown quantity at this point
do you have hardline that connects to high pressure power steering? (only if this is a dual cam)
kocampo1 is offline   Reply With Quote
Old 03-02-2014, 07:54 PM   #26
drifter92
drifter92's Avatar
still have lots of parts including rear 5-lug hubs
Old 03-05-2014, 06:42 AM   #27
drifter92
drifter92's Avatar
