Old 03-09-2014, 06:57 PM   #1
husker240
husker240 is an unknown quantity at this point
crank pulley issue
first off, i know what i did was really really really stupid. so i was fixing the timing chain rattle on my 1996 240sx se and was having troubles getting it to start. it started up just fine and then when i went to go test drive it, it died on me. so off course i went through and double checked the distributor to make sure it was line up with the 1st cylinder, it was, so i went to go back and try starting the engine, but i forgot to take my 1/2" ratchet and 27 mm socket off of the crank pulley, now it is leaking oil out of the crank shaft pulley. i need to help as it is my only car and i have work and all that and i can only rent a car for so long... what do i need to replace?
husker240 is offline   Reply With Quote
Old 03-10-2014, 08:18 PM   #2
husker240
doesnt anyone know how i can fix this or what i need to buy?
Old 03-13-2014, 05:19 AM   #3
iBaSiiCk
iBaSiiCk is an unknown quantity at this point
What motor? Sr or ka? Sounds like your going to have to replace the front main crankshaft seal... inexpensive part
iBaSiiCk is offline   Reply With Quote
Old 03-18-2014, 07:48 PM   #4
husker240
its a ka24de. well i replaced the front main seal after dealing with 3 wrong seals order by autozone. and when i was looking over the crankshaft pulley, i noticed that there is a nice crack in it. i have tried searching all the standard online sites for one, but all i can find is a underdrive or a $630 ati damper. do you know where to get a stock replacement one or could i just go with an underdrive and worry about replacing the seal more often? i have had good luck with isis products. here is the one i saw http://www.enjukuracing.com/products...91%252d98.html
Old 04-11-2014, 04:24 PM   #5
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
I have done the same thing, left my ratchet on the crank pulley and it loosened the bolt by itself. I didn't find it loose until months later when it started leaking out tons of oil. Also my crank pulley also cracked. I bought an ASP under drive crank pulley to replace it with but ended up buying a used oem one to pass smog here in california.
DennisC is offline   Reply With Quote
crank pulley, leaking, oil, stupid
