04-13-2014, 09:18 PM | #1 |
Help installing speakers
So got everything off for a 6.5 Hybrid Audio speakers to replace front OEM.
I am stuck here though... and seems like I might need an adapter plate? Or do i just go to a stereo shop and fork out the dough? Thought this would be a sinch |
04-13-2014, 10:13 PM | #3 | |
04-13-2014, 10:33 PM | #6 |
im not too worried about the adapter plate. i can prob as mentioned above go to a stereo shop/ebay and mount it.
my question is the wiring.... in the pic posted, you can see the white socket and then a brown connector to the left of it. Thing is my new speakers dont have the same white socket for an easy plugin... |
04-13-2014, 11:29 PM | #7 |
Trader Rating: (29)
Feedback Score: 29 reviews
Wow really? You didn't mention anything about wiring in your OP. So how are we supposed to know what you need help with? We are not mind readers.
Anyhow cut the connector off and solder or use crimp connectors to wire up your new speakers. Done. You could of simply cut you some slack off the connector, wire it back up the factory speaker and used a 9 or 12v battery to pop the speaker to see if the polarity is correct. When the speaker pops forward is the correct polarity. From there you can figure out which color wire is pos and neg. Here is a video that will demonstrate how to check for polarity. http://www.youtube.com/watch?v=TFlwINTNFqg OR You can be lazy and spend a lil money and just buy the plug and play speaker connector. http://www.amazon.com/Metra-72-7400-.../dp/B0002BEQX4 I'm going to assume you want me to give you a wiring diagram for the speaker wires too? Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Blue Right Front (+) White Right Front (-) Black Compliments of: http://www.the12volt.com/installbay/...tail/1598.html BTW All this was found on Google in like less than 30 seconds. |
04-13-2014, 11:34 PM | #8 | |
Too bad im a complete noob to solder/crimp connecting...so I guess I gotta go to a stereo shop |
04-15-2014, 06:41 AM | #9 | |
Crimping a wire is easy (takes like 2 seconds) https://www.youtube.com/watch?v=zdZuBw_wLX4#t=82 |
04-13-2014, 11:49 PM | #10 |
Trader Rating: (29)
Its a crimp how hard can it be? Buy some connectors use a wire cutter that has a crimp nub and squeeze it together.
Strip the wire of the plastic insulation, place bare metal part of wire into connector, use tool and depress on the crimp move on to the next wire. How hard is that? I use both of these: http://www.amazon.com/Klein-Tools-In...=klein+crimper or http://www.amazon.com/Channellock-90...=klein+crimper I have both, they both work fine. Comes in handy if you ever do any type of wiring esp after market car radios. If you don't want to buy tools to crimp just solder its easy as well just a lil more time consuming but it is worth it. It will guarantee your connection for both wires are good. Video on how to solder: http://www.youtube.com/watch?v=HdbFduodOuo You don't need a fancy soldering iron either, a basic one will work fine. Solder is cheap, you can buy it at radio shack, fry's electronics, any electronics store will have it. All the tools mentioned should be basics in any tool box esp if you are getting into car audio or heck even working on cars themselves. If you do not have any of the above items I suggest you invest in them unless you have lots of money to continue to pay people and shops to fix everything on your car. |
04-15-2014, 06:35 AM | #12 |
Hey my old speakers!
When I had them installed on my s14 I snapped the small plastic corner pieces off so the speakers would sit flat against the plastic housing. I then made 1/4" spacers out of MDF to space them out a little. You probably don't need to do this though since those speakers are not that deep. There are existing holes in the plastic housing for screws to hold the speakers in place. These speakers do use spade style terminals so just crimp some of those on and you'll be set. |
04-15-2014, 06:37 AM | #13 |
you can solder spade connecters to the speaker wires and insert them into your OEM connector, thats what I did.
Two wires....man....two wires. Cant wait till a post comes out on how to connect an oxygen sensor... |
