Old 04-25-2014, 10:48 PM   #1
Ying
Ying is an unknown quantity at this point
Toyota Supra MKIV 6 Speed Single Turbo 640whp FS/FT
Hello Lads, I have been thinking on and off about selling my Supra for some time and have decided to finally post it.
I spent the last year turning this into the Supra that I have always wanted. I make all of my cars into vehicles that you can drive every day, without the usual "high hp/tuner car" problems and that was no different for the Supra. It is a full 2JZGTE swap (not an NA-T) with V160, diff, brakes, everything. It makes 640whp 610wtq and can sit in traffic like any other car. It doesn't run hot, the turbo isn't a lag monster and your leg won't die from a ridiculously heavy clutch. It is something you can use every day. It runs E-85 as it is close to my house but can run 91 safely if you just drive normally (a retune on 91 is easy too if you would like a map switch to interchange fuels). The heater blows hot and the A/C works but is missing one line for it to blow cold.
1995 Toyota Supra, Clean Title California car with a slick top and OE spec aftermarket sunroof. Tags are good for another six months or so and it currently has around 142,xxx miles.
Maintenance: A car that runs is always the most fun so the first thing undergone was the following maintenance (unless otherwise noted all of the maintenance, fabrication, tuning, service and work was done in the last year)
-Timing Belt (full service done by technician at Capitol Toyota)
-Water pump
-All Belts
-Cam Seals
-Front seal
-All fluids
-Crank Pulley
-Spark-plugs
-oil changed regularly with OEM filter
-PMU G-Four $75 brake fluid
-New (~1000 miles) Dunlop ZII’s
-New throw-out bearing
-New transmission seals all around
-New Pilot bearing
-Solid tripod bushings (for shifter)
-Valve-stem seals replaced in 2010
-Metal upper coolant hose
-All intercooler couplers are silicone with T-bolt clamps
Modifications:
-Borg Warner S366 9179 Turbo
-Boosted Labs replica manifold (with slight porting and Spoolin Performance V-band welded on for wastegate)
-Tial MVR44 wastegate (will come with all extra springs, currently has 15psi spring IIRC)
-Spoolin Performance Wastegate dump, level with bottom of car
-Spoolin Performance custom 4” piping from the turbo out. V-band on all connections minus off of the turbo as Borg Warner uses a Marmon flange (same principle)
-HKS TI 4” catback, recently refinished/clean tip and V-band installed
-Spoolin Performance cold side intercooler piping (one-piece to reduce amount of couplers used)
-Trust/HKS (can’t remember) intercooler
-HKS SSQV
-Custom 4” intake with massive K&N filter
-Princess Motorsports stainless steel oil lines for turbo
-AEM V2 standalone ECU
-AEM 3.5 Bar MAP sensor
-Borg Warner Intake air temp sensor with MAC solenoid for ECU controlled boost
-Tuned by Lawrence at LS Fab on the dyno and street for best drivability. Currently runs a straight veggie diet of E-85 but can easily be tuned for 91.
-RC 1200cc injectors
-Dual Walbro fuel pumps in-tank
-Stainless steel fuel lines with inline filter
-Aeromotive Fuel pressure regulator
-New (~600 miles) Southbend Stage 4 Feramic Clutch and pressure plate (replaced all bushing, seals and gaskets while in there)
-Short Shifter
-Dual Electric fans with shroud.
-All “aftermarket wiring” (boost solenoid, fans, mac sensor, etc.) were wired by LS Fab for a clean install. OEM power plugs from the stock twin VSV’s were used to run power for an OE looking install and for shorter runs of wire.
Extras:
-Rare Greddy mechanical boost gauge
-KPH JDM speedo
-New Leather Upholstery (no rear seat belts)
-Clifford Alarm with pager
-HKS turbo timer
-PLX wideband
-Buddy Club driver seat rail for bucket seat (can be included)
-RMM Style lip
-Pioneer double-din screen with DVD player (radio antenna isn’t hooked up)
Suspension:
-Volk GT-U’s (good condition, freshly coated in Ceramic Pro)
-Tein Coilovers
-Cusco front and rear strut brace
-Project Mu G-Four brake fluid freshly flushed
-PLX wideband
Detail:
-Paint has always been cared for but a full paint treatment/restoration was just undergone with ~70 hours gone into it
-Full claybar, cut, polish was completed this month. This detail was followed by the Ceramic Pro Silver package coating. It was applied by the only Ceramic Pro certified shop in California. Ceramic Pro is an extremely hard coating that adds a level of depth and intensity to the paint. This hard coating resists water spots (beads better than nearly any wax), rock chips and even "key marks".
-Wheels, glass and headlights were all coated in Ceramic Pro as well. The headlights also underwent a lens restoration.
-The paint is original and does have a couple blemishes. Someone put a small key mark in the passenger door. Only visible when up close in the right light and the rear left quarter has a small patch of faded paint. Other than those two areas, the paint is incredible and feels like wet glass.
-The interior was also professionally cleaned with a special coating on the leather to keep it looking fresh. Original carpets and floor mats look great, all of which (front and rear) are present and will go with the car. Comes with original roll out trunk cover.
Car will come smogged, professionally washed again and the interior will again be cleaned for a nice transition to a new owner.
Asking $36,000 obo. I am open to trades as well. Just let me know what you have. Nothing beat up though please. Very interested in a tow car, something like a Cayenne S or a drift car plus cash.
Dyno Run https://www.youtube.com/watch?v=kWUU-zsvkXo
Ying is offline   Reply With Quote
Old 04-26-2014, 02:27 AM   #2
rb27dets14
rb27dets14 has a little shameless behavior in the past
Sunroof completely ruins an otherwise awesome car.....glws
Quote Originally Posted by andresr20
ffffffuuuuuuuuuuuuukkkkkkkkkk HONDAS
rb27dets14 is offline   Reply With Quote
Old 04-26-2014, 03:34 AM   #3
Ying
When I first bought the car I would have agreed with you. Having lived with it for awhile now, I actually really like it! Turbo spooling sounds, wind in your hair...kinda fun lol.
Old 04-29-2014, 10:19 PM   #4
Starlet119
Starlet119 is an unknown quantity at this point
Thats the stupidest thing I've heard in a long time, i take it you've never owned one? Is a targa any better? Op good luck with your sale, looks like a clean swapped n/a.
Starlet119 is offline   Reply With Quote
Old 04-30-2014, 10:48 AM   #5
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
Not factory sunroof. That's the problem.
babowc is offline   Reply With Quote
Old 04-26-2014, 07:40 AM   #6
BooStedS13SleePeR
BooStedS13SleePeR is an unknown quantity at this point
Send a message via AIM to BooStedS13SleePeR
This car is beautiful but 40k for a NA swapped supra is ehh.. And the sunroof . But GLWS im sure someone will appriciate it.
BooStedS13SleePeR is offline   Reply With Quote
Old 04-26-2014, 09:48 AM   #7
Double-R
Double-R is an unknown quantity at this point
142k at that.... GLWS
Godzillas
CTMMA
Double-R is offline   Reply With Quote
Old 04-26-2014, 11:18 AM   #8
nissanhoe4show
nissanhoe4show's Avatar
Trader Rating: (31)
nissanhoe4show is an unknown quantity at this point
Feedback Score: 31 reviews
really nice car and tastefully done glws BUMP
nissanhoe4show is offline   Reply With Quote
Old 04-27-2014, 08:27 PM   #9
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
supra forums is a better bet!!
supersayianjim is offline   Reply With Quote
Old 04-27-2014, 08:51 PM   #10
Silvia85
Silvia85 is an unknown quantity at this point
Awesome car man
Silvia85 is offline   Reply With Quote
Old 04-30-2014, 10:42 AM   #11
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
danngggg...
S14kouki_10 is offline   Reply With Quote
Old 04-30-2014, 01:31 PM   #12
Starlet119
I suppose you would be the kind that would build a 1k hp supra and then not drive it or race it, so the miles stay low. Kind off like the people that would pay a premium for a hardtop supra, saying it handles better and feels better under turning ect ect. Then only bring it out for dynos.
Old 04-30-2014, 03:33 PM   #13
Double-R
Personally prefer the sunroof over a targa any day, understandably so it screams this is a NA car.
for those real wannabes that want a hardtop...patching a sunroof is a MUCH easier road to take than bridging a targa.
Godzillas
CTMMA
Old 05-01-2014, 10:05 PM   #14
rb27dets14
I absolutely hate sunroofs... Personal preference...ill take headroom over a sunroof anyway...cars beautiful...I'd deal with the sunroof in this case or make it back to a hardtop
Old 05-02-2014, 06:44 AM   #15
Double-R
Said like a true wannabe
Godzillas
CTMMA
Old 05-02-2014, 11:11 AM   #16
rb27dets14
Oh yea you got me.....I prefer hardtop cars...u prefer balls on your chin...personal preference....
Old 05-02-2014, 07:40 PM   #17
anthonyr sil8ty
anthonyr sil8ty is an unknown quantity at this point
Hahaha, owned!
anthonyr sil8ty is offline   Reply With Quote
Old 05-02-2014, 05:55 PM   #18
t70 supra
t70 supra is an unknown quantity at this point
Send a message via Yahoo to t70 supra
TRADE
95 sc3 DD 1jz vvti r154 301.32 hp ALL STOCK
t70 supra is offline   Reply With Quote
Old 05-03-2014, 10:41 AM   #19
jserman
jserman's Avatar
jserman is an unknown quantity at this point
is this a 6 speed or still have the NA 5 speed also does it have the 6 speed rear diff or the NA one??
jserman is offline   Reply With Quote
Old 05-03-2014, 02:09 PM   #20
Ying
Thanks for the bumps and kind words guys. I know the sunroof isn't everyone's cup of tea. Personally I like it having lived with it for awhile now.
Hi jserman. This has the V160 six speed in it. Like I had mentioned, it is a complete swap with turbo brakes front and rear, LSD, everything
Old 05-04-2014, 06:12 PM   #21
Tico12
Tico12's Avatar
Tico12 is an unknown quantity at this point
BUMP! Beautiful car good luck with the sale
Tico12 is offline   Reply With Quote
Old 05-04-2014, 06:59 PM   #22
Ying
Thanks Tico! Nice MKIV in your avatar
