Unknown Oil Burning Issue
Need help diagnosing a problem. My SR is shooting white and blue smoke out the exhaust when I'm cruising, never when I'm idling. Doesn't smell sweet at all so I don't think it's coolant, definitely oil and some vapor.
I have done a compression test with 140 across all cylinders and a leak down test showed everything was below 10%. I have replaced the valve seals and I got a used t28 to replace my turbo because I thought it was blown. Pulled off my downpipe and there is no oil so it's probably not a blown turbo. Wtf could it possibly be??? Last edited by FourWeeks; 06-18-2014 at 10:07 PM.. |
Check pcv valve on valve cover. Also could be rings but your compression seems OK . To do compression only crank over 5 times full rotation.
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Yeah that's what I figured. I have my valve cover teed off on the right side so I think I'll run it in line with the stock air oil separator. Doubtful it will clear up my issue but I guess it doesn't hurt to try.
My opinion is the intake creates a vacuum to release head pressure and the catch can will catch the oil. A good catch can should keep things working as they should.
#11 | |
![]() Join Date: Sep 2005
for the valve cover t and needing a catchcan in the op case would mean that, the oil has to travel all the way through the pipe work, intercooler and intake manifold, sucked into the combustion chamber to the become the, blueish/gray(white) smoke. This is possible, but since there is no oil in the down pipe.
No oil in piping, but there is residual carbon deposit from when I drove it with the cracked valve seals. I ran seafoam through the throttle body on Saturday and it seemed to reduce smoking to only highway speeds. I'm gonna run seafoam through the brake booster vacuum line as suggested on NICO and report back.
#14 |
No loss in coolant.
Seafoam through vacuum line didn't really help. I'll be taking my turbo off and looking at related parts to see if my turbo has blown seals. Tuner took a look at my lines and said my oil feed didn't have a restrictor on it so the oil pressure could have possibly done some damage. |
#17 |
![]() Join Date: Jun 2013
I'm going to say that "it doesn't have to". Since you have an alluminum block/head, the SR is especially prone to warping. If the deck is warped, but not cracked, you could have oil leaking past only after it's been heat soaked.
Sent from my SCH-I545 using Tapatalk |
#22 |
Do this. Popoff your cold pipe, open the the throttle, and see if there is any oil pooling up in the manifold (I'm assuming you have am S13 SR with the plenum at the bottom)
#24 |
SRs have a 2 part intake. It has the plenum and the runners. The plenum is what the throttle body is conmected to, and it sort of "pools" the air before it goes to the engine through the runners. S14s have plenums at the top, and runners at the bottom. S13s have runners at the top and plenum at the bottom. If there is a lot of blow by, it will blow more oil with it, which gets sucked up by the intake through the pcv and the lines on the exhaust side of the valve cover. If you have a plenum on the bottom, you should easily be able to see if there is any oil build up. Run your car untill it starts shooting blue smoke, then shut it off and take a look.
#26 |
![]() Checked throttle body and plenum and there wasn't any standing liquid, though it appears there was at one point. Pulled off turbo and there wasn't anything outstanding there either. I'm going to buy a catch can today and see if it fixes anything. |
#28 |
Yes I drove around for 30 minutes before popping the piping off. There was shaft play on the exhaust side I think, but I read that ball bearing turbos are supposed to have some when there's no oil in there?
