Old 06-19-2014, 11:16 PM   #1
jamg
jamg is an unknown quantity at this point
coolant need is flucating. VIDEO INSIDE!
https://www.facebook.com/photo.php?v...type=2&theater
my coolant needle is going crazy... it's reading in the middle, then getting to hot, and coming back down.
just now on my drive back home, it went to hot, and stayed at full hot.
my auto meter water temp gauge reads 100*F the whole time.
on my way, it actually fluctuated from 100*F, to 150*F, back down to 100*F
This problem recently started happening. I bled the system already when i swapped in a new rad, and it has been operating at normal temps for a while, until now...
any idea what's wrong?
jamg is offline   Reply With Quote
Old 06-20-2014, 12:14 AM   #2
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Have you changed the smaller CTS on the water neck that goes to the oem gauge cluster? I'd also try bleeding the system again as well.
blksylv is offline   Reply With Quote
Old 06-20-2014, 12:45 AM   #3
jamg
i have not. this roblem happened literally today.
Old 06-20-2014, 07:26 AM   #4
blksylv
blksylv's Avatar
Trader Rating: (33)
Ah gotcha. I'd try changing the sensor and check for leaks in the coolant system if your aftermarket gauge is doing the same thing. Might wanna check grounds as well to make sure none have come loose since it could also be an electrical problem. Does it just happen when you hit bumps? Do you smell burning coolant?
Old 06-20-2014, 11:13 AM   #5
jamg
i bled the system today. there was so much air inside... some how i lost coolant, and it needed to be filled up.
or it just went into the overflow tank and didn't go back in.
Old 06-25-2014, 03:59 AM   #6
S13HB
S13HB is an unknown quantity at this point
Then there is a leak somewhere.
Check the obvious places
Radiator
Radiator cap is holding pressure
Cracks in overflow tank
Radiator hoses.
If those check out, look towards the back of the head and play with those water lines and see if they are leaking. (More than likely your problem if everything else checked/ checks out okay.
S13HB is offline   Reply With Quote
Old 06-20-2014, 11:28 AM   #7
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
It's an overflow tank... not an expansion tank. It's not meant to go back into the system...
You need to replace that sensor. There are 2. One is for the ECU and one is for the dash gauge.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 06-24-2014, 08:49 PM   #8
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
That is NOT true. It is an expansion tank and the coolant will be sucked back into the system when it cools down. I don't know of ANY OE cooling system that does not have an expansion tank.
Old 06-27-2014, 02:31 PM   #9
Def
Every BMW made in the past 30+ years...
They have a true expansion /surge tank, and when the cap pops the coolant goes all over the engine bay. It doesn't pop because there is air space in the tank for coolant to expand into.
DEFSPORT
Old 06-24-2014, 08:08 PM   #10
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
Kallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really nice
Feedback Score: 61 reviews
I agree on replacing the sensor. Should be the one with the spade connector if im not mistaken. Verify the wiring is ok also.
Kallixtos is offline   Reply With Quote
Old 06-25-2014, 12:58 AM   #11
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
And remember nose up of the car to help get those evil bubbles out easier!
Primo's Silvia is offline   Reply With Quote
Old 06-25-2014, 07:43 PM   #12
toyyxvoy
toyyxvoy is an unknown quantity at this point
toyyxvoy is offline   Reply With Quote
Old 06-27-2014, 05:07 PM   #13
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Also i know for a fact early 240z dont have a coolant/expansion tank either.
Also 100f or 150f is rather low. something doesnt add up
Old 06-29-2014, 05:58 PM   #14
Def
It's seeing air because he has a major coolant leak. Then it sees really hot coolant, then air etc.
DEFSPORT
