Old 07-19-2014, 12:43 PM   #1
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
Sr20 hks step 2 264 272 cam questions help
Ok first question do I need cam grears because the 272 exhaust cam? If I can get away with my stock gears do I degree them? Or just set to factory? Thanks for help n input! Set up s13 black top hks step 2 264/272 arp head studs apxi hg June intake man full race top mount 30/76 810cc and on power fc d. Please help would like to have it back togather this weekend thanks
Bnr32gtr is offline   Reply With Quote
Old 07-20-2014, 06:58 AM   #2
Bnr32gtr
Please help guys any input would be greatly appreciated!
Old 07-20-2014, 10:51 AM   #3
jr_ss
Cam gears are to dial in the cams for performance purposes and to extract every last up out of the engine. Without having them(the cams) "dialed" in you aren't going to hurt anything. It requires a dial indicator and/or multiple passes on a dyno, moving the gears in small increments at a time to find the sweet spot.
If I were you, I'd drop the cams in and roll with it. Lots of people do the staggered cam. Obviously, you'd net more gains with cam gears and being able to find the best position for the cams. If this is a mild setup, I wouldn't worry about it.
Old 07-20-2014, 06:48 PM   #4
Bnr32gtr
Thank u sir for the info I'm going to roll with the stock gears on that note. I have hks springs I read I should test them to see if they will need shimmed. How do u feel on this? Thanks again for the Input
Old 07-20-2014, 06:54 PM   #5
jr_ss
The springs shouldn't need to be shimmed. I'd go with the factory spec for shimming your rockers. Check the FSM for specs.
Old 07-21-2014, 05:51 PM   #6
blancrgaza
blancrgaza is an unknown quantity at this point
blancrgaza is offline   Reply With Quote
Old 07-21-2014, 07:35 PM   #7
Bnr32gtr
I keep every thing in order I cant just put them back same order? Or is it to tight with the higher lift cams sorry if this a dumb question? I was under the impression that u want the rocker arm level, (wrong term) sets on with out slack on one side and the hydraulic lifter makes up the rest
Old 07-21-2014, 08:28 PM   #8
jr_ss
If you kept everything in order, just reinstall it as it was.
Old 07-21-2014, 08:44 PM   #9
Bnr32gtr
Thank you friend very helpful
