Old 08-07-2014, 08:09 PM   #1
abbSC
abbSC is an unknown quantity at this point
RB25 crappy throttle response- help
Alright guys, I recently got my rb25 back in my car and running but throttle response sucks and Im not sure why. Quick list of mods: tomei drop in cams, HKS adjustable cam gear (EX), top mount manifold, precision sc61, tial 44mm gate, front mount, turbosx RFL Bov, freddy intake, q45 throttle body, top feed rail with bosch 850s, AEM fuel pump, etc. running just off the down pipe right now. Im using a Apex-I power fc w/ map sensor and have the fuel somewhat tuned. The car is drivable but my throttle response sucks. Its slow and not smooth at all like the rb used to be. I can blip the throttle and it takes a second for any response. Now I was told it may be that the car needs to be fully tuned, but a friend was able to get his SR running great with a very similar setup and we didn't touch ignition tuning yet on his. We timed the rb correctly and also experimented with adjusting my exhaust cam. 2 degrees retarted and the car ran even worse and would die coming to a stop. 2 degrees advanced and it runs about the same as at 0 degrees. Any input is appreciated as I am dying to drive this thing.
Thanks
abbSC is offline   Reply With Quote
Old 08-12-2014, 08:31 AM   #2
abbSC
still having trouble..
Old 08-12-2014, 08:40 AM   #3
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
You throw big injectors, big turbo, aftermarket intake manifold and big TB at it and you're wondering why it's not running right without a tune?
hobbs is offline   Reply With Quote
Old 08-13-2014, 07:05 PM   #4
abbSC
Just expected throttle response to be a bit better then it is considering we didn't have this issue with my buddies sr. AFRs are tuned fine
Old 08-12-2014, 09:12 AM   #5
Croustibat
put that car on a trailer, bring it to a mechanic so he can fix your mistakes (namely set the cams and CAS right, remove boost leaks) , then to a tuner so he can tune it.
And THEN you can drive it.
Old 08-13-2014, 07:08 PM   #6
abbSC
There are no boost leaks, been over everything and the car has good vacuum and holds any boost fine. Cams are timed correctly and so is the CAS. I do need to get it tuned by a pro but I just thought it would run better then it is now.
Old 08-14-2014, 02:00 PM   #7
TwoForDeh
TwoForDeh's Avatar
TwoForDeh is an unknown quantity at this point
did you take the vct out when you put the cams in? If you did, rb's are complete dogs low rpm/response wise with no vct let alone being untuned with everything you have.
TwoForDeh is offline   Reply With Quote
Old 08-14-2014, 02:41 PM   #8
abbSC
VCT is still installed
Old 08-14-2014, 02:12 PM   #9
OBEEWON
OBEEWON's Avatar
Timing..........
Old 08-14-2014, 04:22 PM   #10
Sileighty_85
Sileighty_85's Avatar
needs to be tuned. Power FC Base maps are only intened to be drive to a tuner, not DD'd.Q45 TPS probably needs to be adjusted, if its a Series 2 IIRC S2's will have issues wih the Q45 TPS.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
