Old 08-09-2014, 11:32 AM   #1
white_z3nk1
white_z3nk1 is an unknown quantity at this point
RB25 parts, s14 parts F/S F/T
Finally took some time to actually take Inventory this morning. Prices are obo but keep it reasonable.
95 S14 Zenki stock grill - 20
RB25det oem upper intercooler pipe with stock bov - 50
RB20det rear fuel injector harness for injectors 4, 5, and 6 - 20
KA24de s14 Automatic transmission computer 40
95 S14 oem fuel pump with no strainer - 40
RB25/20det turbo outlet/O2 sensor housing 6 bolt - 45
Slanted exhaust tip - SOLD!
KA24de s14 power steering fluid reservoir - 25
KA24de s14 power steering high pressure line - 25
9006 12000k HID bulbs - 20
HID ballast - 10 each
RB20det oil pan bottom has some dents but never leaked - 65
98 S14 OEM intake assembly with used filter - 25
Evolution IX MR stock turbo outlet/O2 sensor housing with sensor - 60
Black racing steering wheel with red stitching - Sold
95 S14 oem gauge cluster in unknown condition - 20
95 s14 oem cruise control sensor - 20
92 s13 gad pedal - 15
2.5" intercooler piping with Apexi twin chamber bov - 180
RB25det stock valve covers - 50
RB25det stock Intake manifold - 50
RB25det stock cams with light surface rust - SOLD!
RB25det resurfaced head, valves may need to be checked - SOLD!
KA24de s14 ECU newer condition - 75
KA24de s14 ecu was working when pulled not as new looking - 60
98 S14 "catalytic converter"... lol or at least it looks like one - 15
KA24de s13 valve cover blue chipping paint, clean on the inside - 30
98 s14 stock open differential, needs diff mounts, using a 4 bolt back cover, should drop into an s13 in its current setup - 50
msg me for further contact info
Following trades considered for: 97-98 s14 kouki hood, s14 rear subframe, s14 crackless dash, s14 dual n1 tip catback, RB25det transmission, poly motor mounts (I have the mount kit just not the mounts), s14/s13 front coilovers, s14 steering rack, S14 JDM kouki oem rear spoiler, S14 USDM kouki front lip, RB25det clutch kit, RB25det flywheel
white_z3nk1 is offline   Reply With Quote
Old 08-30-2014, 09:20 AM   #2
white_z3nk1
Updates:
Black racing steering wheel with red stitching - SOLD!
Old 09-07-2014, 04:46 PM   #3
TunanS14
TunanS14's Avatar
TunanS14 is an unknown quantity at this point
Do you have a "CA" ECU? Aka 1996 240sx 5 speed
Instagram @Fatlaced40
TunanS14 is offline   Reply With Quote
Old 12-19-2014, 01:27 PM   #4
white_z3nk1
Sorry for the lack of replies. been super busy.
Still got pretty much everything listed!
