Old 08-30-2014, 03:09 PM   #1
SR20DET-B2200
SR20DET-B2200 is an unknown quantity at this point
s14 fs-tw-ebt-trade1995 zenki, KA24DET, haltec, Cold AC, REAL Battles, gtr shit, silkroa
For sale, possible trade, partial trade plus cash, testing waters. Not needing to sell but money is nice.
$8500 obo
**few things I forgot,
CAR IS LOCATED IN OXNARD CA 93030
CAN DELIVER CAR WITHIN REASONABLE DISTANCE
REGISTERED IN FLORIDA TAGS ARE EXPIRED. Clean Florida title on hand.
DOES NOT PASS SMOG IN CALIFORNIA.
CAR CAN BE PAINTED COLOR OF YOUR CHOICE FOR VERY REASONABLE AMOUNT AND A DEPOSIT.
1995 base model zenki. No rust, no major damage, never hit in front like every other 240 I've seen.
Link to previous owners thread...
http://zilvia.net/f/showthread.php?t=384170
My goals were to make the car look as stock as possible on the outside except for wheels n tires.
I've removed all the s14.5 parts and gone back to all oem zenki.
Car has full functioning lights again, wipers n windshield washer work, ac works perfect. Fans come on with ac and at 190 via haltec. Had over fenders and flared-rolled fenders. All holes welded up, not just bondod up. Wheel openings have been hammered n dollied and pulled back into shape. No bondo on them but they could use Lil more work. Or overs if you like. Core support re worked to fit r32 gtr intercooler for stealthiness. Condensor and radiator moved back about 3" all custom piping made up.
Motor and trans:
*Garrett GT3076R dual ball bearing turbo*
Full custom 3" mandrel bent from turbo back. Buddy club resonator before axle and dual 2.5" exit magnaflow at back. Looks very stock.
Mazworx Ka tubular turbo manifold
Turbonetics Evo Wastegate 5 pound springs (controlled by profec B Boost controller )
HKS SSQ 3rd Gen BOV
SS oil feed and return lines
Innovate LC1 Wideband
INNOVATE*Oil Pressure, water temp, boost/vacuum gauges
GReddy ProFec B Digital Boost Controller*
GReddy Turbo Timer*
FUEL:*Walboro 255 fuel pump
Precision 780cc Injectors
Turbo240 AMS Top feed Fuel Rail
Z32 Fuel Filter
SS Fuel line with AN fittings
Tomei FPR and Gauge
R33 GTR intercooler, radiator and condensor moved back to allow intercooler. Has stock bumper support and se fog lights. Full custom intercooler piping.
MAf Delete (Haltech)*
Cooling: CX Racing ka Aluminum*Radiator
CX Racing Dual Electric fans
CX Racing Aluminum Fan Shroud*
190 Degree auto on fan switch regulated through the Haltech
Eagle H Beam Rods
JE Forged Pistons 89.5mm dish 9.0:1 compression
Hot Tanked
Bore matched for Pistons
All brand new Bearings, Clevite*
XCessive ka-t oil pan
GReddy SR20 oil sump
Head:*BC Stage 2 264 Cams
BC Complete head Kit, Valves, Springs, Titanium Retainers,
Cometic Headgasket
ARP Head Studs
Intake Manifold Simplified and clear of all nonsense (EGR, IVAC)
Fresh resurface with front timing cover for no leaks
Tranny:*ACT 4 puck unsprung clutch
ACT High*Pressure*Plate
Fidanza Lightweight*Flywheel
New Pilot Bearing
Driveshaft*Shop 1 piece*Aluminum Driveshaft*
B&M Short Shifter*
B&M*Shift*Knob*
Tuning/ Ignition:*Haltech E6X Standalone Engine Management System*Ls1 Coil packs (4) (Distributor Delete)
Magnecor Custom Race Ignition Wires*
NGK*Spark*Plugs*
Suspension: Silk Road RMA8 Adjustable Coilovers*
Peak Performance RUCAs, Rear Toe links
Peak Performance 5 lug Hubs
Z32 front Calipers and Rotors, (circuit sports drilled and slotted rotors
Cusco Front Strut Tower
Kaaz 2-way
Stance solid raised subframe bushings.
New inner and outer tie rods and boots
Energy suspension rack bushings
Megan raising tie rod spacer
Yamato garage tension rods
Wheels:*18x9.5 +23 battles with brand new 275/35 hankook ventus evo v12 tires.
Interior:
R32 gtr seats.
Cracked dash
Nice carpet, could use cleaning
Has nice ac trim piece
New shift boot and bezel
Panasonic deck.
JL audio rear speakers
Infiniti reference coaxials in front
Have greddy turbo timer, profec ll boost controller, not installed
Innovate wide band, boost-vacuum, oil psi and water temp. Not installed.
8500. Might be priced lil high, might not. Mainly looking for cash, trades will be considered. Lmk what you have. Willing to sell with se stocks for less, Megan track coilovers for less , no seats for less. That's about it.
805-407-5415, call or text. Text is best. DO NOT TEXT ME AFTER 10PM. Any time from 6am to 10pm is fine.
SR20DET-B2200 is offline   Reply With Quote
Old 08-30-2014, 03:34 PM   #2
SR20DET-B2200
Old 08-30-2014, 03:40 PM   #3
SR20DET-B2200
Old 08-30-2014, 03:40 PM   #4
SR20DET-B2200
Old 08-30-2014, 03:42 PM   #5
SR20DET-B2200
Old 08-30-2014, 03:43 PM   #6
SR20DET-B2200
Old 09-01-2014, 11:52 AM   #7
SR20DET-B2200
Forgot to mention I do have another headlight, hood and fender barley got any damage. Most likely will be fixed soon .
Old 09-01-2014, 12:00 PM   #8
240sx guy
240sx guy is an unknown quantity at this point
Youll b golden with a clean paint job man!!
240sx guy is offline   Reply With Quote
Old 09-01-2014, 12:00 PM   #9
240sx guy
Real nice interior man!
Old 09-01-2014, 12:05 PM   #10
Dcocci
Dcocci is an unknown quantity at this point
PM sent. Clean title?
Dcocci is offline   Reply With Quote
Old 09-01-2014, 12:06 PM   #11
240sx guy
Old 09-01-2014, 10:13 PM   #12
the-rusty-240
the-rusty-240's Avatar
the-rusty-240 is an unknown quantity at this point
You need a paint job baaaaad
the-rusty-240 is offline   Reply With Quote
Old 09-01-2014, 10:57 PM   #13
SR20DET-B2200
Yes i t needs paint. I figured I'd put it up for sale as is. I know that I am a little hesitant to buy something that has 'fresh paint'
With this one there's no surprises hiding under there.
Old 09-02-2014, 11:44 AM   #14
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
I can vouch for tommy. Legit guy. Hate to see this go.
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 09-03-2014, 05:37 AM   #15
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
So where is the car at? Your location says California and the car has a Florida tag on it..
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 09-03-2014, 08:58 AM   #16
SR20DET-B2200
Located in 93030,,Oxnard ca
Old 09-07-2014, 09:29 PM   #17
SR20DET-B2200
You buy now!
Can also be sold on the volk gtc wheels
Old 09-11-2014, 11:51 AM   #18
abcdefg123
abcdefg123 is an unknown quantity at this point
Part out? Bump
abcdefg123 is offline   Reply With Quote
Old 09-12-2014, 04:10 PM   #19
SR20DET-B2200
At this point I'd rather keep it for a shop parking lot toy than to part it out. Make offers!
Old 09-17-2014, 01:11 PM   #20
SR20DET-B2200
TTT don't make me paint and keep this car.... I'll lose my license if I do.
Old 10-02-2014, 10:32 PM   #21
SR20DET-B2200
Buuump. Still for sale ish.
Old 10-17-2014, 09:56 AM   #22
SR20DET-B2200
Omg still for sale.
Old 10-17-2014, 09:39 PM   #23
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Your parts list is right, but the appearance of your car is not.
Look at those pics, and ask yourself if this LOOKS like an $8500 car.
Old 10-18-2014, 12:07 AM   #24
SR20DET-B2200
Paint can hide a lot of bad, I'd rather have something original or showing dents than 'ready for paint' or, 'freshly painted. But that's just me I guess.
Old 11-07-2014, 12:06 PM   #25
SR20DET-B2200
Still for sale, even tho it looks like I'm just going to keep and finish it. I'd like a daily and or some cash for other projects
Old 11-10-2014, 05:04 PM   #26
newbie_s13_coupe
newbie_s13_coupe is an unknown quantity at this point
What kinda trades are you thinking of?
newbie_s13_coupe is offline   Reply With Quote
Old 11-11-2014, 07:14 AM   #27
SR20DET-B2200
Pretty open to most non fwd trades. I have 10 cars and they're all pretty much projects in different stages. Would be nice to get a daily. Newer Tacoma, is300, BMW wagon, or something like that, classics are good too
Old 11-11-2014, 09:06 PM   #28
ihaveaz32
ihaveaz32 is an unknown quantity at this point
wil you trade for a 1993 300zx twin turbo?
Low N' Slow crew
ihaveaz32 is offline   Reply With Quote
Old 11-12-2014, 08:14 AM   #29
SR20DET-B2200
No thanks on the z32, thanks for the offer tho
Old 11-12-2014, 02:19 AM   #30
kpc_0721
kpc_0721 is on a distinguished road
Tell me you're joking when you say "Real Battles"
kpc_0721 is offline   Reply With Quote
battles, jdm, s14 ka-t, these battles are real, turbo, you buy now
