![]() I dont know if I need and alignment or bad tie rods but my car skids on outter wheels when im driving straight and louder skids on turns. It wastes the tires on the outside. Also wheels seem to have slight camber in front (stock suspension) but going out from top and bottom going in. Rear is good. Have coils there. Also when I turn right my steering wheel is straight after I turn and on left turns, then steering wheel is crooked after turn is done and I'm going straight. On bumps it slightly shifts to the side. Anyone can help before I spend on something that's not the problem? Thanks.
![]() Last edited by nano; 10-08-2014 at 04:28 PM.. |
![]() Join Date: Feb 2006
The steering issue is your steering rack mounts/bushings.
It also sounds like your ball joints are shot. The best way to know for sure is to get under the car and inspect stuff. Shake the wheel and look for play side to side and up and down. |
![]() Join Date: Jun 2010
uhhh what??? your alignment is wayyyyy out of wack then. see if its coming from the back or front. maybe your tie rod is bent. you can just eyeball the alignment so its not that bad until you get a real alignment.
