![]() Join Date: Jan 2003
ka24de swap wont start!!! help !!!
hey
i just finsihed my de swap and now it wont start. it cranks pretty strong but it wont completely start. i took out the fuel lines and when i tried to crank it again it wouldnt pump out gas. Then, my neighbor took out his timing gun and checked if the coil had sparks and it didnt. I had another coil and it didnt have a spark either. How can two coils be bad? Ive had the worst luck with the swap and this caps it. Can anyone help? thanks |
![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
So no spark?
I know this sounds stupid but did you check the fuses? (dont mean to insult you but this has happened to me a few times) Iv'e also done the following genius manuevers. Ecu Plugged in? Grounds Attached? Relays Plugged in? Battery Charged? Distributor Attached? If the component isn't working trace back to the source of the power.
#3 | |
On a early model production year 95's, both the fuel pump AND the distributor use the engine block as a ground point. That ground point is located towards the rear of the left side of the engine block around where the Oxygen sensor is located. There is also a secondary ground wire that connects from the engine block to the firewall. Make sure both those wires are connected. Your car should start once you get all your ground wires properly connected and grounded. Anyhow, hope this helps...good luck!! ID '95 SE |
