Old 12-15-2014, 09:45 PM   #1
helix73
helix73's Avatar
helix73 is an unknown quantity at this point
HELP All 4 Brakes Continue to Lock Up
So in the past 48hrs ive had continues problems with my brakes, they just randomly started to seize up on my way home, so i replace my BMC and thought it helped. But my rear calipers were still sticking, so i replaced them because the piston boot was damaged, but still the problem continues. So i took apart my front calipers and cleaned them and ended up replacing the slider pins on the bracket because they weren't well lubricated and were stuck. But still my brakes continue to stick after about 2 or 3 pumps on the pedal. Im replacing the brake booster tomorrow.
Has anyone else had this problem?!
helix73 is offline   Reply With Quote
Old 12-16-2014, 01:05 AM   #2
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
This happened to a buddy of mine, i never witnessed it myself but he tried to explain to me that the cause of the problem was in the brake pedal?? He claimed the previous owner shoved a bolt in somewere and it will slightly begin to jam after a couple mins of driving?? So its funny to say but check your brake pedal while your at it lol
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
Old 12-17-2014, 11:37 PM   #3
helix73
helix73's Avatar
yeah that ended up being my problem. Someone had put a bolt in its place and i guess the back fell off over time. Fixed it with zip ties!
Old 12-18-2014, 01:09 AM   #4
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Holy crap I can't beleive this actually was the problem haha..dam gotta love the online forums
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 12-18-2014, 10:04 AM   #5
firejackal
firejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enough
Besides this I've seen people use bolts in replace of the plastic inserts that is suppose to hit against the brake and clutch switches. And half of those I've seen didn't put a nut on the other side so the bolt would often jiggle around and get stuck at different angles.
Join my discord server! https://discord.gg/SDN7fw2
firejackal is offline   Reply With Quote
