Old 08-11-2004, 12:49 AM   #1
Adikt
Adikt's Avatar
Adikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura aboutAdikt has a spectacular aura about
Send a message via AIM to Adikt
5 speed Swap Question
Ok I'm starting my 5 speed swap soon and have all the parts but I was looking through the service manual and found this
now i have a few questions about that part.
1. What the hell is that?
2. What does it do?
3. Is it really needed for the 5 speed swap?
Adikt is offline   Reply With Quote
Old 08-11-2004, 02:01 AM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
would they have put it in there if it wasnt needed. shit I know people that all their career they try to eliminate lil parts like a screw, that will end up saving the company millions down the road, now by eliminating that my friend, would make me (nissan) BILLLLLLLLLLLLLLLLLLLLLLIONS. so um yah its needed. looks like it would help support the shaft, and its got a gasket so im sure it is lubing the shaft and also by removing it you would be letting lube in the bellhousing. y, does yours not have it or what?
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 08-11-2004, 03:12 AM   #3
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
I think he thinks from the pic, that it just sits "out there". as a seperate peice from the tranny. I have done the the sr/ka tranny swap twice, and the ca/ka once. They both are very similar. That thing that you think is needed for a 5spd swap, is just a casing inside the bellhousing that slides over the imput shaft. There are five bolts that connect it to the bellhousing, then there are two C clips behind that. This part is one of the two sections needed to disconect the bellhousing from the tranny. This part you talk of, is the tranny, and not a "5spd swap part".
-Snail
TheSnail is offline   Reply With Quote
Old 08-11-2004, 04:19 PM   #4
Adikt
Adikt's Avatar
sry but i thought that was the manual transmission mounting plate. umm so i guess my next question would be is the mounting plate neccesary in the swap
Old 08-11-2004, 06:29 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
yes .
Old 08-11-2004, 08:13 PM   #6
projectRDM
projectRDM's Avatar
The piece you have circled is part of the transmission, unless you removed it for some reason you don't need a new one. You can remove it if you want, but the throwout bearing will be riding on the input shaft and the 2.5 quarts of gear oil you just poured in will be swimming in the bellhousing.
FORMERLY R240NA
Old 08-12-2004, 11:23 AM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Isnt that the tranny seal? Well lets just put it this way, when i blew my KA tranny, I punched a hole on that metal plate and had fluid leaking thru that damn thing.
CLICK HERE!!!
