Old 07-16-2015, 09:13 AM   #1
petrolhead575
petrolhead575 is an unknown quantity at this point
S14 with S13 SR won't start
Hey everyone, I have a s14 SE with a s13 sr and had some issues with it this morning. Last night I installed a new valve cover gasket (could be irrelevant but thought I'd add). So this morning the car starts right up with no issue, it runs for about 30 seconds and it turns off with the key in the on position. I double checked the ground on the valve cover since I took it off last night and it was okay. When I put the key in the on position, none of the cluster lights come on, the radio doesn't turn on, nothing turns on. The headlights still work and my e fan switch still works so I ruled out the battery. I checked all of my fuses on the kick panel and the engine bay and they are all good. When I turn the key, the fuel pump doesn't turn on and the starter doesn't click and the engine doesn't crank. Something is pointing me in the direction of the factory alarm system which I don't have a key fob for, the car is parked in a garage was not tampered with overnight save for the valve cover gasket install. Can someone shed some light on this?
petrolhead575 is offline   Reply With Quote
Old 07-16-2015, 02:25 PM   #2
r.coffie10
r.coffie10 is an unknown quantity at this point
I had a semilar problem with my 180sx sr20det could not figure it out but the problem it wont start my lights everything worked but the fuel pump wasnt so i replace it with a new one because i was going to upgrade anws but the new one wasnt working either so we knew that it had to be in the wiring because like you we checked all the fuse everything looked ok i went to a guy that specialize in wiring and he cheked my harnass all the wiring and he solve the problem run me some new wiring and the car was like it was again it gave my headache because i bought sum new parts $$ the car was like for 3weeks park and ot was a litle problem in the wiring hope that could help
r.coffie10 is offline   Reply With Quote
Old 07-16-2015, 03:07 PM   #3
Supastar Bruce
Supastar Bruce is an unknown quantity at this point
DId you check all the ground on the engine block?
To me it sounds like you have a lack of ground somewhere. Battery to chassis ground ok?
Supastar Bruce is offline   Reply With Quote
Old 07-16-2015, 03:33 PM   #4
petrolhead575
Currently at work but first thing I'm going to check when I get back is all of the grounds, lack of ground is starting to make more sense. Thanks for the input everyone, will give an update soon.
Old 07-17-2015, 07:16 AM   #5
metako42
metako42 is an unknown quantity at this point
Could also be a faulty ignition switch and it was just a coincidence that you just replaced the gasket. After all it did run for 30 secs.
metako42 is offline   Reply With Quote
Old 07-24-2015, 11:23 PM   #6
kane01
kane01's Avatar
kane01 is an unknown quantity at this point
Yeah it was running and died. Ignition or relay go bye~bye.
From your moms basement / using hacked rotary phone
kane01 is offline   Reply With Quote
