Old 07-20-2015, 04:51 PM   #1
2plus4plus0eq6
2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known
Clicking / Ticking Noise.. Possibly arching from plugs?
Hey guys,
I hear this weird ticking noise when my car idles, it clicks quicker when rpms increase but only so a certain point... like 2500.
I googled a crap load and thought maybe it was arching from my plugs. I took all the plugs out and cleaned them, checked them for proper gapping and secured everything back down. It still seems to click. I have even messed with my TPS thinking it was something to do with that.
I am running NGK BRK7E gapped at .028
Is this normal? Any suggestions?
2plus4plus0eq6 is offline   Reply With Quote
Old 07-20-2015, 06:40 PM   #2
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
That's typical for a car with vtec.
Ilya is offline   Reply With Quote
Old 07-20-2015, 06:41 PM   #3
2plus4plus0eq6
I have an sr20. Is that typical then too?
Sent from my SM-G900W8 using Tapatalk
Old 07-20-2015, 06:41 PM   #4
Beijing_Raccoon
Beijing_Raccoon is an unknown quantity at this point
^Yep.
You didn't even list what car or engine, so the best that can be assumed is something with vtec.
Beijing_Raccoon is offline   Reply With Quote
Old 07-20-2015, 06:43 PM   #5
Ilya
Ilya's Avatar
Can you write out the pattern in which it ticks? I'll look it up in my Nissan manual once I know the pattern.
Old 07-20-2015, 06:48 PM   #6
2plus4plus0eq6
O I don't think I could figure that out. It happens too fast and you can't really pin point exactly where it's coming from.. like which coil pack, etc.
Is it possible that it could be coming from one of the cylinders. Would it be dumb to try and disconnect 1 coil pack at a time to see if it stop the noise or would that cause more problems?
I can try and upload a video when I get a chance
Thanks.
Old 07-20-2015, 06:54 PM   #7
Ilya
Ilya's Avatar
No no no no I need the pattern spelled out. If you post a video then I would have to inerpret the numbers clicking instead of you, and only the true owner can recognize the pattern.
You can try to disconnect the coil packs but you can never disconnect the coilpack in a consecutive direction: example of what I mean. Disconnect cool pack, reconnect coilpack, disconnect coilpack to the right of first coilpack I disconnected, now I can not disconnect a coil pack to the right of the second coilpack because that ruins the pattern so you have to disconnect to the left.
Old 07-20-2015, 07:21 PM   #8
2plus4plus0eq6
Sorry for my Noobness but how would I go about getting this pattern?
Old 07-20-2015, 07:17 PM   #9
burnsauto
burnsauto's Avatar
http://www.harborfreight.com/mechani...ope-69913.html
Done.
Old 07-20-2015, 07:18 PM   #10
2plus4plus0eq6
Looks expensive LOL
Old 07-20-2015, 07:19 PM   #11
2plus4plus0eq6
Originally Posted by 2plus4plus0eq6 View Post
Looks expensive LOL
I just clicked the link... my bad... 4 bucks hah
Old 07-20-2015, 07:34 PM   #12
cameronfaley
cameronfaley is an unknown quantity at this point
On a different story excluding spark plugs or coils... A possible clicking/ticking noise could be a lifter tick. But this early on i wouldn't specifically pinpoint that as your problem.
cameronfaley is offline   Reply With Quote
Old 07-20-2015, 07:35 PM   #13
2plus4plus0eq6
Thanks. I'll do some research on that and keep it in back of my mind
Old 07-20-2015, 07:37 PM   #14
cameronfaley
Yeah no problem! Good luck to you!
Old 07-20-2015, 07:45 PM   #15
jr_ss
What motor is this again? S14 VTC? It's your VTC cam gear. You need to replace it.
Old 07-20-2015, 07:50 PM   #16
2plus4plus0eq6
Ya it's a zenki s14 sr20. You've had this problem before? Can't be fixed, just replace the cam gear?
EDIT: I just watch some youtube videos, and the noise I am getting is no where near as loud as the ones in these videos. Its not a rattle. It literally sounds like a small arching noise.
Does not sound like the VCT rattle:
https://www.youtube.com/watch?v=qHfdF0aLUrw
https://www.youtube.com/watch?v=95qdoK44zQg
Old 07-20-2015, 08:35 PM   #17
burnsauto
burnsauto's Avatar
hmm...possibly a collapsed lifter? They can range in loudness depending on how much fluid is left in the lifter.
Old 07-20-2015, 08:52 PM   #18
jr_ss
Can you take audio of the ticking? It may just be your injectors...
Old 07-21-2015, 10:08 AM   #19
chancelton
chancelton is an unknown quantity at this point
That's a weird tick....doesn't sound like injectors or like it's in the motor either. Good luck with that
chancelton is offline   Reply With Quote
Old 07-21-2015, 10:53 AM   #20
jr_ss
Great helpful post. Keep posting uselessly to get that post count up, idiot.
It's hard to say what exactly it is. I would say it's more of a faint tapping sound than a tick/click. If you want something to do, check your valve train. Make sure your lifters are bled and the shims are within spec. A bearing on the front of the motor might be going bad(I.e. Water pump, tensioner). There are a lot of things this could be. Replace your plugs, if they have a brown trace mark on the ceramic, they are bad.
I honestly don't think it's anything to cause alarm or worry. These motors seem to have a lot of random noises.
Old 07-21-2015, 11:04 AM   #21
2plus4plus0eq6
Ya thanks for your help. The car seems to drive fine. I do have a new water pump that I could throw on. I'll mess around with it. At first I was really concerned, but now I am over it lol
Old 07-21-2015, 11:11 AM   #22
chancelton
actually, it was helpful as I stated that I did not believe it to be in the engine or an injector. process of elimination. i dont give a fuck what my post count is, you on the other hand are the "post whore" fucking troll
Old 07-21-2015, 12:47 PM   #23
jr_ss
Wow, another educated response, you're on a roll pal.
Old 07-21-2015, 04:25 PM   #24
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Lol. He's a "post whore" who joined at the end of 2005.
Lol, such a post whore, fucking troll!
Sorry, I'm just trolling.
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 07-21-2015, 09:27 AM   #25
2plus4plus0eq6
Here is a video I took of it. I increased the rpm probably no higher than 1500. You can really hear the noise at the end.
Let me know if the link doesn't work - Video
Old 07-21-2015, 12:01 PM   #26
burnsauto
burnsauto's Avatar
I'd get a stethoscope and at least look into it. Sometimes you can catch a little problem before it develops into a big one with a tool like that.
Old 07-21-2015, 12:02 PM   #27
2plus4plus0eq6
Thats a good point. I will try and pick one up. thanks
Old 07-26-2015, 11:08 PM   #28
kane01
kane01's Avatar
kane01 is an unknown quantity at this point
Lifters and rockers tap. Exhaust leak is usually a tick accompanied with soot and exhaust smell. Lower end is gonna be a knock, obviously louder and deeper than the top end noise. Injectors tick and so does your spark if it grounds out just right and the spark is stretched a little. Are there performance symptoms that will help us find waldo.
From your moms basement / using hacked rotary phone
kane01 is offline   Reply With Quote
Old 07-27-2015, 09:11 AM   #29
2plus4plus0eq6
I haven't noticed any performance problems other than some boost hesitation which can come from my controller and some backfire
Old 07-29-2015, 11:36 AM   #30
2plus4plus0eq6
UPDATE:
I had misdiagnosed my engine. I thought it was the VTC solenoid. It was actually the TPS. When I did a check on the TPS, I had noticed it was turned all the way clockwise. I checked the FSM and did a resistance test on it.
FSM states:
throttle released = 0.7 ohms
partial = 0.7 - 5 ohms
WOT = Approx 5 ohms
Mine was totally off. I got my throttle released now set to 0.7 ohms. which is perfect. I can't quite get my WOT to 5 ohms. I get approx 4.1 ohms. I know the FSM says approx.
I had an issue with backfiring and this has seemed to stop it. The car runs way better, quieter, smoother, more power. No more clicking/ticking noise.
BUT... on the downside, my car seems to die a lot more often when coming to a stop. I have a lightweight flywheel and drive shaft. Found what I have read, there is not enough inertia to stop the engine from stalling when coming down from revs. I am pretty sure I need to now try and increase my base idle. Because now after messing with my TPS, I have noticed my idle is a lot lower than it was... and it was low already before!!!
Pretty embarrassing I tell ya when driving around and stalling. Some hot tart on the sidewalk watching and laughing thinking I can't drive stick lol
My tach is not working at the moment due to have a sohc cluster with my sr20. Anyways I think I can raise idle with the IACV.
Any comments or questions are appreciated
EDIT: I was able to raise the idle. Not sure its set at, but I don't seem to stall at stops now. It still drops down a lot, but then bounces back enough to keep car alive. I am happy. I might raise idle a little bit more in near future. Not sure how much more screw can come out lol
