Old 08-24-2004, 05:30 PM   #1
Ritz S14
Ritz S14's Avatar
SR short shifter in a KA will it work?
Just bought a C's Short shifter off of ebay.. it listed "JDM C's SHORT SHIFTER S13 S14 R32 R33 Z31 240 300 Z"
But not until after the auction it says "This is a C's short shifter from a RB20 DET Skyline. It was installed, but the box and manual was still in the car. This shifter will fit SR20 transmissions, and RB20 Transmissions"
Will it fit or am I screwd? I did a search on "short shifters" but all I got was results from the For Sale section
Ritz S14 is offline   Reply With Quote
Old 08-24-2004, 05:37 PM   #2
orion::S14
orion::S14's Avatar
If it fits an SR transmission, it'll fit a KA tranny.
- Brian
Old 08-24-2004, 05:40 PM   #3
Ritz S14
Ritz S14's Avatar
Thank you SO MUCH!!
Old 08-24-2004, 10:03 PM   #4
projectRDM
projectRDM's Avatar
CA, RB20, KA, SR, VG30E, all the same transmission. Common knowledge.
FORMERLY R240NA
Old 08-24-2004, 10:34 PM   #5
silverside
silverside's Avatar
silverside is an unknown quantity at this point
different bellhousing
cheap and fast is not reliable, cheap and reliable is not fast, fast and reliable is not cheap
silverside is offline   Reply With Quote
Old 08-25-2004, 09:11 AM   #6
projectRDM
projectRDM's Avatar
True, but same case. Ass.
FORMERLY R240NA
Old 09-01-2004, 09:46 PM   #7
Ritz S14
Ritz S14's Avatar
Another question. I just installed the shifter, but for some reason the plastic cap on the end of the shifter(where it connects to tranny internal linkage) is larger than the female connection on the tranny. So I took that part off, now it's metal to metal, but the shifter goes in. The throws are dramatically decreased, but is it normal to be able to lift the shifter up about 1/2" to an 1"?
I read the installs section, but it didn't say any
Old 09-01-2004, 09:46 PM   #8
Ritz S14
Ritz S14's Avatar
Another question. I just installed the shifter, but for some reason the plastic cap on the end of the shifter(where it connects to tranny internal linkage) is larger than the female connection on the tranny. So I took that part off, now it's metal to metal, but the shifter goes in snug. The throws are dramatically decreased, but is it normal to be able to lift the shifter up about 1/2" to an 1"?
I read the installs section, but it didn't say anything about having so much play when you lift it up, since the old barely had any.
Thanks in advance.
Old 09-01-2004, 09:49 PM   #9
orion::S14
orion::S14's Avatar
You forgot to install the metal spacer ring, eh?
And for that bushing...it should be in there, just sand it down a little and pop it in. Tighter is better.
- Brian
Old 09-01-2004, 09:58 PM   #10
Ritz S14
Ritz S14's Avatar
I did..it goes on the very bottem about 1/2" thick.
I'll post up a pic in a bit.
Old 09-01-2004, 11:25 PM   #11
Ritz S14
Ritz S14's Avatar
With the left cover removed, it fits in nicely. But I think that's what gives me a lil buzzing sound. The stock cover (right) I highly doubt will fit, cause the C's shifter's "ball" is about the same size is that plastic thing. I might have to force the left cover in the shifter input in order for it to fit... any other suggestions? I guess i'll try shave it down a bit to make it fit.
Another thing I might add.. Is then when it's in gear, it doesn't have any vertical play, just in neutral.
More pics...
Old 09-06-2004, 05:55 PM   #12
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
I've had experience with a couple of C's shifters. Basically, a brand new S14 C's shifter fits all RB trannys, S13 and S14 trannys according the to owners manual just like yours.
Your looks odd though.The plastic bottom piece should not be that big at all. It should look exactly lilke the stock piece. Also, the square machined metal piece looks a bit thick. Here is an example of an S13/S14 C's that fits perfect (I bought this particular one myself from Japan):
I would almost be 100% convinced that it would fit without problems looking at that chassis list, but the physical aspects of the shifter just don't look right. That plastic piece makes all the shifts very snug and eliminates any play.
TurDz is offline   Reply With Quote
Old 09-06-2004, 06:14 PM   #13
Ritz S14
Ritz S14's Avatar
Well with the bottem piece removed, it works fine. I took your advice on the redline heavy gear oil, and it seems to work well. Not that there were any problems from before. Pretty much preventive maintainence.
Old 09-06-2004, 09:06 PM   #14
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
wat the heck when i went to japan monkey magic told me that the uras shifter wont work on the ka transmission, so i ddnt buy it. they said the sr nd ka had differnt trans so it wont work!!
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 09-06-2004, 09:41 PM   #15
projectRDM
projectRDM's Avatar
You think they know about KA transmissions in Japan? It's not like they're doing USDM tight installs of KAs like the lemmings here in the US do SRs.
FORMERLY R240NA
Old 09-07-2004, 01:25 AM   #16
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Hmm...everybody said the KA and SR shifters are interchangeable but for some reason the shifter i got from my SR tranny was different...basically i tried to use my KA short shifter and basically the stud after the ball is taller than the stock SR one so I ended up jes using the stock SR shifter.
CLICK HERE!!!
