Old 10-06-2015, 05:16 PM   #1
SLYDEWAYS 96
SLYDEWAYS 96's Avatar
Trader Rating: (34)
SLYDEWAYS 96 is an unknown quantity at this point
Feedback Score: 34 reviews
2003 Nissan 350z Enthusiast 6spd
NOT FOR SALE...MODS DELETE POST
Contact - PM or text / call 5163484478
Location - Queens / Long Island NY
Mileage - 104xxx
Silverstone exterior / Black cloth interior
Enthusiast includes LSD / Traction Control / HIDS / Sport aluminum pedals
Car has a cd009 6spd transmission (bulletproof triple plated carbon synchros) from 06 350z, dealer fixed.
Clean NY title, no accidents/ 1 prior owner.
No cel / dash lights. Inspection passed.
Maintenance: All done within past 5k miles
New thermostat / Coolant flush
Brakes and Rotors all around
Front and Rear Timken wheel bearings
Front and Rear Moog sway bar end links
Moog inner and outer tie rods
Alignment recently done at NFS NY
Synt Oil Changes every 3k miles 5w30 Castrol
New clutch / pressure plate/ flywheel / slave & master cylinder
NGK Iridium Spark plugs
New oem camshaft position sensors
New oem pcv valve
Redline trans and diff oil
Replaced both valve covers due to common spark plug seal oil leak
Modifications
Bassani true dual SS catback exhaust
Custom intake, z1 wrinkle black tube with k&n cone filter
Motordyne copper isothermal plenum spacer kit with throttle body gasket and lower manifold gasket
z1 red silicone brake booster vacuum hoses
BC Racing Coilover Suspension with 10k front 8k rear spring rates
SPC Rear Camber arms
cr kai reps (vordoven) Hyper Black Gunmetal color
Front 18x9.5 Rear 18x10.5 with 22 offset
Fenders professionally rolled
Achilles atr sport 2 tires. Very sticky. 265/35 Front 305/30 Rear
Gorilla forged steel extended lugs
07 brake calipers all around which means bigger pads and rotors
Has stoptech street pads with centric high carbon rotors.
Stoptech SS Braided brake lines
JWT Clutch kit (exedy stage 2) with light weight 14lb flywheel done at 102k
New OEM clutch master & slave cylinder with SS clutch line
Pioneer double din radio w/ bluetooth and aux
Mishimoto weighted shift knob
OEM Nismo floor mats
Authentic MOMO steering wheel
NRG Quick Release & NRG wheel hub.
OEM JDM fairlady z exterior badges
Ebay front lip
Titek CF front air duct
G35 coupe rear mud guards
Acura MDX short antenna
CF roof spoiler
Kicker 6in speakers all around
Depo blackhoused HID projector headlights
Sylvania 6k hid bulbs
35% tints all around
50% tint front windshield
***Will include stock 17s with general artic snow tires for the right price. Tires only used for 1 winter.
Car is not perfect for being 12 years old, but its one of the cleanest Z's around
Front bumper is loaded with rock chips, typical for 12 year old car.
Driver quarter panel could use a wetsand and reclear. Clear peeling in 1 spot, nothing crazy.
Interior is 10/10 condition
Engine is very healthy, does not burn oil, no funny noises.
Suspension is good, not too stiff, can be adjusted for different height and softer ride.
Overall a clean car. Was my daily driver but looking for a bigger car.
Car was waxed, detailed and sealed every 3 months.
Will take trades for evo 8 / wrx / legacy gt / b6 s4. Manual only
Let me know what you have. Open to all trades, no fwd.
$11,500. Will not remove any mods to lower price.
Invested over 5k in the car with maintenance and modifications.
Drives & handles great, very quick car, fun to drive.
SLYDEWAYS 96 is offline   Reply With Quote
Old 10-11-2015, 05:23 PM   #2
SLYDEWAYS 96
Trader Rating: (34)
bump someone buy this
Old 10-12-2015, 06:16 AM   #3
STR8 H8N
STR8 H8N is an unknown quantity at this point
you are priced pretty high for an 03 with 100k+
STR8 H8N is offline   Reply With Quote
Old 10-12-2015, 08:39 AM   #4
driftsucky
driftsucky's Avatar
driftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond repute
He said on a forum where 20+ yr-old cars with over 200k+ on the chassis are posted for more than 2500 bux because of a motor and some needed maintenance.
@be_henney kranstogram is full of nonsense and foolishness.
driftsucky is offline   Reply With Quote
Old 10-12-2015, 09:40 AM   #5
STR8 H8N
http://zilvia.net/f/showthread.php?t=613644
Old 10-12-2015, 09:52 AM   #6
driftsucky
driftsucky's Avatar
I commented on that one too.
Old 10-22-2015, 06:08 PM   #7
SLYDEWAYS 96
Trader Rating: (34)
Delete post...keeping car...ended up buying 100shot wet kit. racekor
Old 10-23-2015, 06:16 AM   #8
STR8 H8N
good thing you did bc it was a tough sell
because racecar
