Old 09-01-2004, 04:36 PM   #1
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
SR problem..Choking under light throttle. Mafs???
Well i have a problem with my redtop. Under light acceleration my engine will start choking when i hit 2500rpms and up in all gears, it would choke then stop for a couple of secs then choke agian and agian etc. If i go to medium or hard acceleration there will be not problem at all. I first thought my mafs could have been messed up so i used a sohc mafs. For anyone using sohc mafs on there car the pins go like this correct?
SR ----------- KA
B -----------> A
C -----------> B
D -----------> C
This is what i found on NICO, but it seems that it may not be the MAFS if the wiring is correct. What else could be the problem?? Please help.
My mods are:
Intake, downpipe, test pipe, and exhaust. Thats all...
Thanks
Life is good in the bay.
Eternal_240Sx is offline   Reply With Quote
Old 09-02-2004, 12:00 AM   #2
rico05
rico05 is an unknown quantity at this point
If it happens EXACTLY at 2500 RPM then it is the MAF. Throws your ECU into "lipm home mode" and kills revvs above 2500 to keep the engine safe. Can't tell you if wiring is different cuz I have a CA myself, but I am using a KAE MAF as well.
rico05 is offline   Reply With Quote
Old 09-02-2004, 08:00 AM   #3
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
maybe your wiring is cutting some time so its run in safe mode for a moment then run okay .. tuka tchek your ecu for code should be the first step in troubleshootting.
F3600 is offline   Reply With Quote
